Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
The codes I got say running lean on bank 1 and bank 2....guy at parts source thinks its a vacuum leak. I took it to a buddy (backyard mechanic ) but very good at detecting these things Im told, he cant find a vacuum leak but he thinks its the intake manifold gasket....
any suggestions? this is about a $400.00 job Canadian funds....the dealer is about double that Im told... not sure what else it could be...he said the egr was working fine he tested it with a vacuum pump..did a few tests etc... thanks for any input... Dave |
Re: Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
Do a search on this forum. There are endless amounts of threads on this issue and very likely your problem is the Isolator bolt deteriorization that causes an intake leak around the port seals.
If you do searchs here, you will find that many of us have had the same problem. Your mechanic buddy is close.... manifold gaskets .... and in particular, "isolator bolts" ... which are part of the gasket/seal scheme for the upper intake manifold. The isolator bolts have built-in seals that seal the manifold "spacer" to the lower metal manifold.
I had the same thing on my 99. I have since cleaned the Mass Air Flow sensor in the aircleaner with brake cleaner and also replaced the left valve cover & pvc as indicated in the TSB listed below. It's been over a month with 800+ miles and no return of the codes. But still have a constant pinging problem.
The information on the following page has great detail on the TSB that was issued for this problem. http://leckemby.net/windstar/windstar01.html |
Thank you all for the help...
Dave |
so you didnt replace the gasket set or isolator bolts?
thanks for any other tips.. Dave Quote:
If grnf did not replace the bolts and seals my guess is that by cleaning the MAF it is now reading more accurately. Of course no more air is entering but the reading from the MAF is indicating that more is and a slight increase in fuel is calculated and delivered. Perhaps his seals are just starting to leak but not enough to register an error with the cleaned MAF. (but it did with the dirtyMAF) My guess is that he simply bought himself some time. I hope this is not the case for his sake.
what is a DPFE ? what does that mean if I order the part?
thanks |
DPFE = Differential Pressure FEedback sensor. It monitors the EGR system flow rate.
The DPFE is another common failure for the 99s and perhaps a few other years. It gives a different code or two. (401???) When you get this failure it is about a $70 part and 15 minutes to repalce so not a huge deal.
Re: Re: Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
Sorry for not getting back sooner . Not yet on the isolator bolts or gasket. But I'm thinking I will end up doing it since it is still pinging. |
Re: Re: Re: Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
Re: Re: Re: Re: Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
You might think about trying the Seafoam treatment discussed in another thread. It might remove enough carbon deposits to reduce the pinging.
1997 Pathfinder XE Air Lift Air Bags, Warn Hubs 2000 Windstar SEL |
Re: Re: Re: Re: Re: Need Help With 99 WIndstar Check Engine Light ...codes p171 & p174...
Carbon deposits inside the cylinder. This would effectively DECREASE the chamber size (in the head) and thus compression would increase. This could cause pre0ignition otherwise known as pinging.
Unless of course Lewis is refering to something else. Are you getting a flashing CEL? indicating a misfire? This could be mis-described as pinging too. Last edited by DRW1000; 04-13-2005 at 07:11 PM. Reason: correction |
