Hi, all.
2000 LT model Venture and it has given me a lot of miles in the last 15 or so years. But now it's the driver's side headlight that won't work. I've replaced the bulb and tested the connector with a test light. No high beam or low beam. Test lamp lights on left and center connectors appropriately. Assuming the wires go straight through the connector that's green for high beam and tan for low beam. The third connector shows continuity to ground. Left side works correctly for low and high beams. When testing the ground connector I tested all three points and the all show continuity to ground. I'm guessing this means the connector is bad or there's a short between both green and tan wires somewhere between the left and right headlights. Does anyone know if the wires go from switch to both left and right, or from switch to left to right (there is a wiring conduit running along the top of the bumper), or switch to right to left? Or have any other ideas? Thanks, EW |
Re: Headlight on driver's side not working
This is a very simple circuit to test with a test light....
Take your test light and attach it across your battery terminals and note the brightness of the light..... Now with the test light still attached to the negative cable, turn low beams on.....probe the terminal in the socket with the tan wire going to it....test light should be bright.......now turn on high beams and probe the terminal with the lt green wire to it, and it should be bright.....if neither is bright, repeat the test by shaving the outer layer of insulation of each of the wires going into the socket, about 3" back......if now bright, replace the socket..... If the first test shows the test light bright at the socket contacts, now move the test light clip from the neg term of battery to the pos terminal, and probe the terminal in the socket that goes to the black wire...if the test light is bright, like the other two terminals, bad bulb.....if the test light does not light, shave the black wire back 3 ", and probe, if it lights, need socket....if it doesn't, you have an open ground wire......easiest fix is to run a redundant ground wire to the black wire.... |
| Tags |
| headlamp , headlight |
