Old 04-05-2005, 11:03 PM
DjEarth DjEarth is offline
Antifreeze leaking
Noticed some antifreeze on the garage floor this morning. I was told by the local shop that mt waterpump needs to be replaced and am just wondering if the leaking antifreeze can come from this problem..or is it the radiator itself?
Old 04-05-2005, 11:23 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: Antifreeze leaking
It most definitely can and is very common.
Mark's Garage est. 1983
Old 04-05-2005, 11:32 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
if its a dex cool system (your 99 blazer should be) yes its verry possible, i jsut did my wp in my 98 s 10 pu, and at advance they said they get a lot of pumps for the s searies
Old 04-05-2005, 11:39 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Park it overbight and then if you see some coolant on the ground note what is directly above the leak.
Old 04-06-2005, 02:33 AM
rental blazer rental blazer is offline
Re: Re: Antifreeze leaking
it is very possably the water pump and it is easy to change yourself for 30-40 bucks i did it myself last month mine is a 85 but mine only had 48k miles before going out on me and i got a lifetime one from napa and when i removed the old pump i could tell it was the same brand but i have been told it is common and well it is very simple to change so try that and see if it helps if you plan ot keep it more then 50k more miles go ahead and get a lifetime one .
Old 04-06-2005, 08:18 AM
Allbert Allbert is offline
Just did my '98's water pump this past weekend... have also heard quite common. Was easy to see that coolant was coming out of my pump when it failed. Be sure to post if you have any questions about replacement process. One tip I'd give is to make sure the back cover screws of your new or rebuilt pump are tight before you install it... the AutoZone pump I just put on appears to be seeping a bit past the rear cover gasket.
Old 04-06-2005, 04:07 PM
Picked up the pump today, I ahve a friend that is a partsman and a talanted mechanic that will be doing the job on Saturday. I did what ya said LT, and it is definatly coming out from the pump.
Thanks for the info everyone. I'll post back if we have a severe problem.
Old 04-06-2005, 05:05 PM
BlazerLT's Avatar
AF -Advisor
post when you got it fixed.
Old 04-10-2005, 04:13 PM
All fixed up and no more leaking at all. Took a bit longer then expected.. 2 hours turned into 5 hours. Thanks for the info here
