J30 electrical problems
I changed the light bulbs in map light on my 1993 J30. After I did that they worked for like a minute then nothing. Now my dome light won't work. When I first start the car the wipers go off once then stop. If I have the trunk open the keychain door lock will not work. If the trunk if closed then the alarm and doors lock fine. I took the bulbs out and still have the problem. I even removed the entire assembly (the power sun roof) and still have the same problems. Also the door ajar light would come on when I turned on the map light. That stopped but sometimes the door ajar light comes on for a few secs when I start the car.
Does anyone know what is wrong? Is it a fuse going bad? Or a fuseable link? It is more of a pain since I have no dome light at night but I dont want the problem to grow. |
Re: J30 electrical problems
what it could be is you have a shorted in your car mabye a ground is touching power meaning postive
Whatever you might do wrong with the map light does not cripple your car...
11 year old car connections are mostly oxidized. This means problems are juts waiting to pop in. That is why people buy new... First thing with such a nice machine (I've got one) is to work around all wirings. Take out every (=every) connector everywhere, inspect, clean, add VERY small drop connector greaze. All small ctrl tubings under the hood: take off, cut 1/4" off, insert. This is quite a job, takes one-two days but is worth it. Check/clean the fuse panel slots with inserting hard carboard in each slot, replace all fuses (some very nasty intermittent problems with 'hollywood' fuses...). Now electrical contact problems will be a distant memory. Except electronics which I doubt in this case... |
Re: Re: J30 electrical problems
just my 2 cents, not trying to dog you in anyway but dont taek wild guesses at things if you really dont know what is going on |
Re: Re: Re: J30 electrical problems
"...im gonna have to call bs on this one. "
- Today too many rely on "call bs" fortune telling instead of Truth. - Here the Truth is found in the schematics. Like just about any electrical circuit... - Basic lamp wirings should not be confused to electronics. Shorted wires [if fusepanel has melted] might however stink of bs. - Map lamp wirings goes to a fuse in any car. Short circuiting it blows its fuse, not bs fuses. That is all. Sorry about that... - Make an empirical test - and "call bs" is revealed! - Dimmers have a dimmer circuit, some types of them can be burn ed with a short. - The whole car can surely be burned. But. It Is a Separate question -like glob all war ming muppet show... "just my 1 cents, not trying to dog you in anyway but dont taek wild guesses at things if you really dont know what is going on" Last edited by Nahkapohjola; 12-02-2004 at 05:33 AM. |
Well What do you know about this car the J-30
opcorn:
Re: Re: Re: Re: J30 electrical problems
also if you short to a wire that has a high resistance that you wont supply the additional current to blow a fuse and you will be giving current from one wire to another that possibly has lower current, therefore blowing that fuse but still suppling it power. it also may be a wires to a componant after a switch, if the switch is closed (i.e. wiper motors turning on during start) than you dont send your current to the fuse cause there no damn completted circuit in that direction of the circuit. i am going to stop goin on cause youll come up with some retarted comment trying to defend yourself and your pride not realizing that you really dont know much about what you are argueing about, where did you learn this stuff anyway?? |
Speaking of obvious did you read the original post? Is the bulb in the map light Before or after the fuse? I can't imagine how just changing the bulb could cause a short in wires that are nowhere near it. Maybe I just have a poor imagination. P.S. Sorry, I know this doesn't contribute anything new to the topic but it bugs me when people comment on something without thinking about it.
Speaking of obvious did you read the original post? Is the bulb in the map light Before or after the fuse? I can't imagine how just changing the bulb could cause a short in wires that are nowhere near it. =why repeat the facts above...? Maybe u just have a poor imagination. P.S. Sorry, I know this doesn't contribute anything new to the topic but it bugs me when people comment on something without thinking about it. Rili.
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
Oops,
I keep forgetting that regular sarcasm is nearly impossible to detect in text. To clarify my previous post was directed toward 94J30t's post, as an attempt to agree with Nahkapohjola's initial response. Sorry for not mentioning that in the first place. There should be a better emoticon or some vb code tags for indicating a sarcastic tone. The rollin eyes just don't seem to be strong enough. |
