Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 04-17-2005, 05:10 PM
pcaulfie pcaulfie is offline
'03 Tahoe, intermittently won't start, loses all power.
The strangest thing has happened twice. I go to start my '03 Tahoe, powers on the gauges for a second, car doesn't turnover, and all power is gone. No power to windows, locks, security, nothing at all.
The first time I pulled some fuses to check if any had blown (none had). Almost ready to give up when viola, power is restored and it started no problem.
Went to start it again a few hours later. Same thing. This time I didn't mess with fuses, I just disconnected the negative terminal of the batter, reconnected it, and power was restored.
What's going on here? Since then the car start up fine, but I don't know what caused this to occur those two times.
Old 04-18-2005, 09:52 AM
BlulytesTB's Avatar
BlulytesTB BlulytesTB is offline
Re: '03 Tahoe, intermittently won't start, loses all power.
Humidity? Dirty terminals... Take a wire brush and clean the terminals on the battery.
2004 Trailblazer LT
Old 04-18-2005, 04:03 PM
I'll give that a try, the terminals are a little corroded. But that would cause me to lose power when attempting to start only?
Old 04-18-2005, 04:59 PM
denialfans denialfans is offline
Mine did that once; all I did was tighten the terminals and it hasn't happened again.
Old 04-18-2005, 06:00 PM
Good to know, thanks for the reply!
Old 04-29-2005, 03:07 PM
caveman87 caveman87 is offline
i would check to see if your terminals are tightened mine did that until i had the terminals fully tightened. then it worked and havent had that problem since
