Go Back   Automotive Forums .com Car Chat > Ford > F Series
F Series Forum covers questions and discussions regarding Ford F-150, Ford F-250, Ford F-350, Ford F-450, Ford F-550, Ford F-650, and Ford F-750.
Old 03-28-2005, 07:04 PM   #1
jcougar88
Running bad
Have a 89 f150 300 6cyl. Changed tps, iac, tune up complete, fuel filter, replaced exhaust system and found out convertors have been reamed out(this could be good). Truck runs good sometimes, bad sometimes(surges, runs really rough), and spits black liquidy stuff out of tailpipe. Anyone got any suggestions on what could be going on? Thanks for any help.
jcougar88 is offline   Reply With Quote
Old 03-28-2005, 08:17 PM   #2
peppermrj
peppermrj's Avatar
Re: Running bad
How many miles and does it misbehave all the time, only cold, low speed high speed, etc.
Also a compression test would be informative.
peppermrj is offline   Reply With Quote
Old 03-28-2005, 08:51 PM   #3
jcougar88
Re: Re: Running bad
Has 64000 original miles. misbehaves at any time. When dribving, runs fine, real smooth like nothings wrong. At idle, sometimes it is fine, sometimes it's rough. Only at idle. Hot, cold, doesn't make a difference. Noticed when it does run bad, it turns over about 5 times before it will start hot or cold. When it runs good, turns over soon as you hit the key, hot or cold.
Old 03-28-2005, 09:16 PM   #4
peppermrj
peppermrj's Avatar
Re: Running bad
Did you check for vacuum leaks (hoses,brittle or gummy,base of throttle body, and around the intake manifold.
I would also check and clean the EGR valve if you have'nt already.
Old 03-28-2005, 10:28 PM   #5
jcougar88
Re: Re: Running bad
have traced and checked every vacuum line on truck. Have not cleaned egr valve, but have cleaned throttle body with about a can of spray cleaner.
Old 03-29-2005, 01:51 AM   #6
peppermrj
peppermrj's Avatar
Post Re: Running bad
Clean the EGR first it is cheap just a gasket and some more carb cleaner. Make sure the pcv rattles and seals well ( I'm sure you did but what the hell). A bad MAP sensor can cause surging. Here is a generic link for testing a MAP sensor.
http://www1.autozone.com/servlet/UiB...3d8004f7cf.jsp
I doubt if it is fuel pressure, clogged or poor connections at the injectors being that it runs well at speed.
Is there anything resembling a choke thermostat?
