toyota wont tell or sell (flargen flaggers) 7m gte
and after the purchase of a $3,000 lab scope (wow what a cool toy) (that seems kind of high priced though) i can say this about the 7m gte
low voltage current delivery from the battery to each and every disturbution box will continue to maintain operations untill the tps checks good now bad now oh good again the cps connector gets cut out hardwired bypassed (what ever your profession calls it) and here is the topper inside the fuse box under the dash there are terminals that look like toy made two solderless crimp spade connectors back to back that brake into two pieces after the fuse has been changed more than 3 times or once by a speical olympics competetor
you cant see them unless you pull the block out and take the top part off the rest of the block dont go any further though or reassembly may be tricky the fix is a secret ill never share the tell tell sighns are l.e.d. brightness during high current demand and wiggiling fuses in a twisting motion makeing both fuse terminals connect.
