1974 Dodge Challenger Electrical Problems
Hi guys,
I've got a 1974 Dodge Challenger that seems to be having some electrical problems. Start it off with how it happened. I was driving home one night when she died in at an intersection. I cranked on it to try and get it to start but it wouldn't turn over. I did so until on the turn of the key everything suddenly died. No power whatsoever. So battery right? I got towed to a nearby gas station and waited for my dad to come. We hooked up the cables and got her started again, but we noticed there was a wire that had come loose (the guy I bought it from messed with all the wiring in ways I will never understand) and was lying on the valve cover. Drove it home and it was fine. The next day on the way to work she died no less than 7 times. Now the only way to get her started is to run a cable from the positive battery post to the coil, and if at any time that comes off she will immediately die. Also at times the headlights and things wouldn't work... just no power at all. Current theories are that that wire that was on the valve cover shorted out a fuseable link or that the ignition system needs to be replaced. Please help! |
Re: 1974 Dodge Challenger Electrical Problems
the only fusable link goes from the starter relay on the fender well right behind the battery. if that is toasted, and you will be able to tell, its only five inches at most, you can buy a roll of wire from napa. thats what i would do if you are not sure if it will keep frying after you replace it. other than that year one sells complete harnesses. if the previous owner did alot of "professional work" on the wiring id replace it. if not you will be in my boat with a burnt up mopar. total the wires should run you no more than 400.
So how many chevy's and ford's does it take to beat a MOPAR? The world will never know! |
check to see if the wires from the coil/distributor and alternator are all connected...must of been previously so you might find the other end of the fried wire. That's whre I would start first. You can get a wiring diagram on line...ALWAYS good to have one. See if you have power to one side of the ballast resistor with the key on.....
to me it sounds like altinator maybee, if its not working right your battery wont b recharging when u drive, u can go to most auto part stores and get both your altinator and your battery tested to see if something is wrong with either one
