Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-30-2004, 11:06 PM
oni24u oni24u is offline
Question 2 issues - timing and pcv
I need to set base timing on 1990 Suburban 4X4 1/2 ton. What color wires do you need to disconnect the computer and where are they located?
I also removed the emmission pump but now I have a open hole on each valve cover. I have been told I still need to install a PCV. Do I need one for each side? How does the tubing to and from the PCV route?
Thank you in advance.
Old 10-01-2004, 12:41 AM
praisethelowered's Avatar
praisethelowered praisethelowered is offline
Re: 2 issues - timing and pcv
You should be able to put a universal crankcase breather in each valve cover. They are available at most auto parts stores.
Old 10-02-2004, 08:23 PM
chuck's chuck's is offline
To set the base timing you miust disconnect the tan w/ black stripe located underneath the plastic cover on the firewall.The fuel pump relay is also located there.
The wire has a single contact weatherpack connector.Once disconnected you can then set the base timing.
chuck's
Old 04-06-2005, 08:18 PM
mrdood's Avatar
mrdood mrdood is offline
Re: Re: 2 issues - timing and pcv
Hey, I know this is an Older thread, BUT, in my own quest to find this single wire connector to disconnect for setting the Base Timing, I have been led astray by about 2.5 feet.... My connector was on the DRIVERS side engine compartment firewall near the windsheild wiper motor. Took me FOREVER to find it!!!
'89 Suburban, 1/2 Ton, 4wd, 5.7L (350) TBI (Stock for now!)
Old 04-06-2005, 11:03 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Sometimes it's behind the glovebox too.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
