Old 03-14-2005, 08:10 PM   #1
Trueeclipse
Trueeclipse's Avatar
Need new flywheel for a 4g64 help
Basicaly I need a new flywheel and I am having trouble finding one for my 2.4 L 4G64 SOHC Engine ACT doesnt make them for my car ={
so what is a good brand to get that will fit my 96 gs spyder eclipse?
Trueeclipse is offline   Reply With Quote
Old 03-14-2005, 08:47 PM   #2
EclipseRST
Banned
EclipseRST's Avatar
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: Need new flywheel for a 4g64 help
Whats wrong with your stock one? If its greased over... Get it turned.
EclipseRST is offline   Reply With Quote
Old 03-14-2005, 09:16 PM   #3
Trueeclipse
Re: Re: Need new flywheel for a 4g64 help
Well my clutch is slipping maddddddd, so Im getting a shop to install a new one (which i still have to order), however my bro told me that I should replace the flywheel too and that if I get a light weight aftermarket one it would provide a noticable differance in acceleration is this true? Also the flywheel has 102K on it.
Old 03-14-2005, 09:54 PM   #4
EclipseRST
Banned
EclipseRST's Avatar
No... He is bullshitting you. The only thing a lighter flywheel is going to help is your rev in neutral. In each gear it is going to be the same as a stock flywheel because you are turning the same force. The flywheel isnt going to help anything!
Just take yours out and get it resurfaced!
Old 03-14-2005, 10:20 PM   #5
Trueeclipse
ahahah are you serious?!
Old 03-14-2005, 10:35 PM   #6
1stGenRocks
1stGenRocks's Avatar
Send a message via AIM to 1stGenRocks
yea just get yours resurfaced. as long as it isnt really bad you'll be fine. make sure that the place resurfacing it does the step height right. if you are getting a act pressure plate then the flywheel's step height should be cut to .612
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
1stGenRocks is offline   Reply With Quote
Old 03-14-2005, 10:43 PM   #7
Trueeclipse
I will be gettin an ACT clutch kit for sure but will it mention the step heigh in the instructions? Also wut kind ACT Kit should I get for myy 2.4L I want something that is for aggressive street driving.
Old 03-14-2005, 10:48 PM   #8
1stGenRocks
a 2600 should be good. it might say the step height in the directions but probably not.
-1stGenRocks-
Old 03-14-2005, 11:13 PM   #9
Trueeclipse
shouldnt the shop know exactly what the step hieght is and can you explain it a little more in depth to me?
