Old 01-13-2005, 05:53 PM   #1
IsuzuJones
Head Gasket or Valve CoverGasket?
I just bought a 1999 Rodeo LSE with 124k miles. Yesterday I noticed that there was a brownish greasy liquid in the radiator, reserve coolant tank and around the coil in the #2 cylinder.
I am also loosing about a quart of water from the radiator every day but there is no noticeable leak in the radiator.
One person told me I needed to replace the head gaskets another person suggested that I only needed to have the valve cover gaskets changed.
I need a third opinion from someone who knows something about this problem. Please help!
IsuzuJones is offline   Reply With Quote
Old 01-13-2005, 05:56 PM   #2
rodeo02
Could be just a bad head gasket, or worse case, a warped/cracked cylinder head. Either way the heads have to come off, be inspected & replaced if neccessary. Your valve cover gaskets (and plug tower seals) will have to be replaced in the process.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 01-14-2005, 09:14 AM   #3
tomlcollins
sorry about your head gasket, let's hope for the best and hope it's not a cracked or warped head, as rodeo said!
02' Rodeo
tomlcollins is offline   Reply With Quote
Old 01-14-2005, 11:19 AM   #4
steveb_92rodeo
If you are going to replace the head gasket(s) anyways, I'd recommend having the head planed at the same time. Might cost you $15 at a machine shop. At the same time, they can dust it and check it for cracks.
It's a PITA when you replace a head gasket only to find out that 2 weeks later the problem comes back, and you have to get the work done anyway.
Steve
steveb_92rodeo is offline   Reply With Quote
Old 01-14-2005, 11:41 AM   #5
Tonupboy
Send a message via AIM to Tonupboy
Re: Head Gasket or Valve CoverGasket?
Is this a recurring problems with Rodeos?? I had my head gasket replaced only to find another oil leak somewhere else...the bottom of my engine is soaked! I cant find the source...all I know is it is dripping near the O2 sensor location and its burning off as it hits the exhaust pipe....what a PITA....
_________________
T O N U P B O Y
"That which does not become a part of the one, shall become one with the void."
Allegiance: None
Function: Universal Dominator
2001 Nissan Pathfinder
1993 Isuzu Rodeo 4WD V6
Tonupboy is offline   Reply With Quote
Old 03-14-2005, 08:35 PM   #6
Screwtape
Re: Re: Head Gasket or Valve CoverGasket?
Tonupboy, have you found the cause of the leak yet? I have been ttrying to find the cause of my leak for almost 3 weeks now. I am leaking bad in front of the engine and on the exhaust mani side (drivers side) in my 98 4 cyl.
I have replaced the front crank seal thinking that might be the problem but nope, not it.
very very frustrating
Screwtape is offline   Reply With Quote
Old 03-14-2005, 11:31 PM   #7
superfret78
Possibly a rear main seal? I didn't think they usually leak that bad....
superfret78 is offline   Reply With Quote
