Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 02-27-2005, 04:54 PM
Staggerlee74 Staggerlee74 is offline
Exclamation 99CL Engine Problem
The check engine light on my 99 CL in on. The cars idles very low & stalls as soon as I push in the clutch (even when I don't attempt to put it in gear). Also, on an intermittent basis, the engine will not tac above 4000 rpm (when the VTEC system kicks in, I believe) I have brought it to the dealer several times & they don't seem to have a clue. First they said it was the O2 sensors, so I had those replaced for $600, then they said the diagnostics pointed to the VTEC solenoid valve, so I had that replaced for $450. Lastly, they claimed it was the car's computer...they installed a salvaged computer for $300. Any ideas?
Old 03-01-2005, 11:23 AM
bigjimslade bigjimslade is offline
Luckily, I have had no problems with my 97 CL.
Since check engine light is on, you must scan the OBDII for trouble codes. This should give you a very accurate idea of what's going on. Don't just start replacing parts for this will get very expensive and won't solve problem.
I am surprised the codes don't pin point the problem!
Old 03-21-2005, 09:37 PM
F23A4Racer750IL F23A4Racer750IL is offline
Re: 99CL Engine Problem
im assuming u have a 2.3CL as the 3.0CL V6 wasnt offered in manual. did u find the problem yet? i just recently bought a 97 2.2CL, hopefully i wont run into problems, i worried about the clutch cuz i bought it with 103,00 at the clock.
