Old 02-10-2005, 02:47 PM
57ringo 57ringo is offline
95 K2500 4L80E problem
My transmission one day would not shift. It acts like it's in 2nd gear. The next day it shifted fine. The day after, it didn't shift again. I shut it off and started it right back up and it worked fine. It set code 81..1-2 shift solenoid, on the scanner. Has anyone had this trouble? What's the cure?
Pat
[email protected]
Old 02-10-2005, 07:27 PM
2000CAYukon 2000CAYukon is offline
Re: 95 K2500 4L80E problem
The 1-2 shift solenoid can be replaced by dropping the tranny pan. There are 4 solenoids, 1-2, 2-3, 3-4 and TCC lockup.
I don't have a manual handy but I could look up which one is the 1-2 shift if you decide to do this yourself.
//2000CAYukon
Old 02-11-2005, 06:35 PM
So you think that changing the 1-2 shift solenoid would solve my problem? I am planning to do this myself so any info would be apreciated.
Old 02-11-2005, 09:13 PM
Is it code 81 or 82? 81 seems to be 2-3 shift solenoid not 1-2. See http://www.troublecodes.net/GM/
The solenoid or the wiring to it is probably bad. The solenoids themselfs are the same (i.e. 1-2 solenoid and 2-3 solenoid is the same part number).
A Factory Service Manual or a Hayes manual would be a good idea.
Of course, this would be a good time to change the filter while you are in there.
//2000CAYukon
Old 02-12-2005, 09:39 AM
Yes, It was code 81. Where is the solenoid located?
Old 02-12-2005, 02:16 PM
When you drop the pan, the 1-2 and 2-3 shift solenoids are at the rear. There are only 2 solenoids at the rear. The drivers side is 1-2 and the passenger side is 2-3.
I have a 96 FSM and it looks like they are held in by a screw (on the 4L60-E, they are held in by a clip). Just disconnect the electrical, remove the screw and replace.
//2000CAYukon
Old 02-14-2005, 08:39 PM
I took the pan off and the NAPA solenoid (#1-5404) I bought doesn't look quite like the original. It has a 2" (about) wire lead which the other just has a place to plug the connection on. I hate when the replacement parts are not exactly like the original. Is a GM solenoid the same or is it different too? What do you use?
Old 02-14-2005, 09:18 PM
My experience is that the ac delco or dealer part is usually the same as what is being replaced. The exception is when something has been redesigned.
The Napa part probably fits many applications and they do not provide the terminal.
I have used Sonnax transmission parts but was unable to find a part number on their website for the 2-3 shift solenoid for the 4L80-E.
//2000CAYukon
Old 02-15-2005, 09:37 AM
I called GM and they told me the 1-2 solenoid was # 10478147 and the 2-3 solenoid was 10478148. Napa has the same # for 1-2,3-4 solenoid, 1-5404.
Old 02-15-2005, 01:00 PM
Most likely the difference between 10478147 and 10478148 is the electrical connection. Since the Napa part does not have the terminal, it can be used for both.
//2000CAYukon
Old 02-15-2005, 07:22 PM
azlincoln79 azlincoln79 is offline
On my 95 overdrive and first are out would the new solenids fix this?
Old 02-15-2005, 07:47 PM
azlincoln,
Have you scanned for codes? Do you have a 4l60-E or 4l80-E?
This looks more like your problem: http://www.transmissionspecialty.com.../77754-09K.htm
Old 02-16-2005, 11:19 AM
It has the 4l80-E with 206000 miles on it first gear will work first thing in the morning when its cold Its been doing this for quite a while and if i remember right it was showing code 81 or 82
thanks
Old 02-16-2005, 11:58 AM
I changed the solenoid and it's still doing the same thing. Code 81 is on it again.
Old 02-16-2005, 03:05 PM
Sorry to hear that. Sounds like something is wrong with the 2-3 shift valve (bad spring, seal or valve body is worn). Or there is an electrical connection problem to the solenoid.
There are valve body repair kits or the valve body can be replaced. I know that the 4L60E has some well known issues with the valve body wearing (the famous P1870 code). I don't know enough about the 4L80E.
Since the valve body needs to come out, now would be a good time to get the 4L80E-HD2 reprogramming kit installed (from Transgo). This kit probably includes new springs for the 2-3 shift valve along with other improvements over the stock tranny. It will also make your tranny last longer (by increasing pressure to the 3-4 clutch pack).
//2000CAYukon
