engine codes
i have a 95 blazer. the check engine light is on i had it scanned and got these codes- p0326 knock sensor 1 ckt range/pref bank 1 or 1 sensor and p0441 evap emission control system purge flow fault.
can anyone tell me what this means and how to fix this also where to locate this? thanks |
Re: engine codes
You need to replace the driver's side knock sensor and service the purge solenoid on your evap charcoal canister.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: engine codes
thank you so much! can u tell me the location of these?
Re: engine codes
I suggest you pick up a haynes or chilton's repair manual for your truck to help you in the future.
Knock sensor is on the driver's side center. I don't know where the purge solenoid is on your truck seing I have never yet had to service one yet.
Re: engine codes
The purge solenoid runs across the drivers side of the upper plenum... Kinda looks like to small vac diaphrams housed in plastic connected by about 1-1/2 inches of 3/8 rubber hose....But just do the knock sensor first (sits between plugs 3 and 5 and has a single wire coming off of it. To remove it use a 22mm deepwell socket. When you pull it, immediately put in the new one as you will drop some coolant...
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Re: engine codes
And make sure you use some thread seal tape on it before you install it.
Re: engine codes
they usually come with orange sealant on it..
Re: engine codes
I am just saying if it doesn't not to install it without any thread sealant on it.
