| Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems. |
Got a question about building a bottom end to go forced induction. Now, what compression ratio is BAD to have on your motor before going FI? Just as an example... I was looking at a B20 swap and it said the compression was like 11:1 (CRV-TEC w/ B16 head and flat top piston) -- so if I went with like the Endyn pistons that are 9.58-10.02:1 would it be worth it as far as power gains if I went with a supercharger -- because arent superchargers designed to run on stock internals anyways? Would I get slightly better fuel economy with the lower compression?
Im not saying im doing that -- but I was just wondering if it were at all possible, and advanced timing... ive been looking at some of these swaps and CRV-TEC says with stock valves on the B16 head that at 4 degree advanced timing they actually touch the top of the piston, but normal timing and even 2 degree timing is ok -- would there be any gain from 2 degree advanced timing? Again, just looking to expand my knowledge -- thanks guys!
AF's Official Asshole RIP AUNIE |
I understand that you werent gonna do the CRVTEC swap but it's a bad idea to do. The compression is too high. If you were wanting to boost any motor then i would go with the LS(either B18A or B18B) because the compression is 9.2:1 and is almost like just perfect for boost. I had a friend named Richie who had a 91 Integra RS boosted at 16 PSi and i think it was just perfect. At the time i didnt like hondas but once i rode in this...i fell in love with them. So that was my long story just to tell you about the LS/GS/RS motor being boosted.
2004 Sonic Blue Ford Ranger XLT 2001 Liquid Grey Metallic Ford Focus ZX3 1995 Integra GS-R - Parting out |
Like I said, im not trying to do this -- just looking for info. And I already mentioned I could get low compression pistons (9.58:1) to help with the forced induction -- that isnt much higher then your friends 9.2 so I dont know why you would say that you cant FI it without problems... now if I was talking about strapping a turbo onto a B18c5 without any compression drops, then hell yes problem city... I just do not see where you get the justification to say that it will be problematic...
If for example it was supercharged w/ upgraded pulley kit for 8 psi -- would I have a problem with all stock parts? And if I would be fine, what would I gain by using a lower compression piston?
You guys are confusing 2 ways to FI.
What you loose in CR you make up w/ boost. So for superchargers if you would do only 8psi, i would recomend gettin it tuned right and stay with stock pistons (unless you want to make bottom end bulletproof) If you went Turbo way, you have a lot more PSI that you got to deal with, so it would be better to lower the compression by getting the 9.xx pistons. but w/ turbo you can run as much PSI as you want untill you start to detonate. |
