Go Back   Automotive Forums .com Car Chat > Chevrolet > Camaro | Firebird > Camaro Discussions
Old 10-23-2006, 01:00 AM   #1
roperstan
Another T-Top rattle!! Can I tighten?
The T-tops on my WS6 are rattling bad. The molding is in great shape, I have taken it to a dealer and they tightened something in the t-tops, they were good for a while, but are rattling again. Anybody know how to adjust the t-tops themselves? I was told before there's a way to tighten the locking mechanism bars. Thanks for any help.
roperstan is offline   Reply With Quote
Old 10-24-2006, 10:27 PM   #2
hotrod_chevyz
hotrod_chevyz's Avatar
Re: Another T-Top rattle!! Can I tighten?
When you flip the t-top switch forward, two little pins about a half an inch long come out of each end of the metal side of the t-top. When you flip the switch the other way they go back in. If you look at the body of the car you can see the holes they go into. Not all t-tops can be adjusted. To see if its adjustable look for the following 2 things;
>the adjustable ones have a round plate surrounding the hole where the pin from the t-top fits into the front and back upper corners of the doorjam. You will see two screws on each one. Loosen the screws back about 1/8 inch. Now you can adjust the top up and down, by rotating the plate clock or counter. You will see the position of the hole move up and down as you rotate each one. Try them one at a time. Adjust one and try it first. Adjust the other only if you have too, and by looking from the side you can tell if it doesnt sit right. If anybody else has seen a different type of adjustment on these post it up cause they are different a little year to year.
nonadjustable ones: Its usually the seals. Over a period of time the seals weaken from being smashed on by a t-top, and natural elements shrinking the rubber. If Thats not it the bodys starting to sag. You can tell the nonadjustable ones because where the adjustable ones have a plate with two screws, instead they have a little hole through the plastic trim and no round plate surrounding the hole where the pin fits.
hotrod_chevyz is offline   Reply With Quote
Old 10-25-2006, 11:12 PM   #3
roperstan
thanks, i definately have one of the newer ones, there aren't any metal plates to loosen and rotate, thanks for your help, i'll have to deal with the seals.
Old 10-29-2006, 11:28 PM   #4
666_speed
Son of Satan
666_speed's Avatar
There are two screws holding the plastic pillar on. With the t-tops out, take those out and you can see where the t-tops lock in place. There are two nuts on the bottom of that, loosen them up to adjust them. Just tighten them back up.
666_speed is offline   Reply With Quote
