Old 09-29-2005, 05:43 PM   #1
EZFrank
need help with codes
I just ran a scan on my 2000 Blazer and codes say air injection system can someone explain what this means or what part that would be. I havent been able to figure it out. Thanks EZFrank
[IMG]http://[/IMG]
EZFrank is offline   Reply With Quote
Old 09-29-2005, 05:55 PM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
Re: need help with codes
Well an important piece of information would be the code number, but luckly there is only 1 code related to SAI.
You have an electric air pump that forces air into the exhaust during cold start-up to reduce emmisions.
Most likely, water has gotten into the pump causing it to lock up and blow the fuse.
The fuse is located near the battery either between the battery and the fender on under the battery tray.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 09-29-2005, 06:18 PM   #3
blazee
Problem?
blazee's Avatar
If your code was indeed the P0410.....
This was originally posted by GMCTech in the Jimmy Forum:
Here's the story on the P0410:
The AIR pump adds air to the exhaust stream to lower emissions. It does this by taking in outside air and pumping it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in the northeast with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
As far as the location of the fuse, it is in the right front fender well beside the battery, and in front of the horn there.
Sometimes replacing the fuse will fix all your problems and you are all set until next winter when it all happens again.
Also, sometimes water is allowed to enter the pump through the intake side of the system (just a 5/8" hose behind the fan shroud) and ruins the system that way. -I'll talk about that in a moment.
GM says that when this system failure occurs due to water intrusion, the pump MUST be replaced. I have had decent luck just blowing the pump out with direct power provided by a test bettery out of the vehicle, and saving the customer some $$$
GM has also released a remote air intake kit that includes a longer 5/8" hose, a control solenoid, and a one-way check valve to eliminate most possibility of water intrusion.
Like I said before, sometimes just blowing out the motor and replacing the fuse will solve your problem. BUT, to truly repair the problem correctly the AIR pump, the fuse, and the exhaust check valves must be replaced, and the remote air intake kit must be installed. $$$
I have much experience with this AIR system. Here in the northeast it is a BIG problem, and we have replaced at least 100 AIR pumps in the last 2 years or so.
If your vehicle is still under warranty, then you are lucky. --> The exhaust check valves usually wear out after 3-4 years thus, putting most vehicles out of warranty coverage.
Hope this explains the infamous (at least here in the northeast) P0410.
blazee is offline   Reply With Quote
Old 09-30-2005, 10:48 PM   #4
tom3
Might read your warranty close. This is an emissions device so it may have a longer warranty. Maybe not but worth a look.
tom3 is offline   Reply With Quote
Old 10-01-2005, 05:57 AM   #5
EZFrank
Would like to thank you all for the help i will be checking it today will let you know what i find.
[IMG]http://[/IMG]
