Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Off-Topic
Old 02-18-2005, 09:42 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Still knocking!! WHAT CAN IT BE!!??!!
Alright. Im kinda pissed right now. I got those mounts installed this week. I bought them because the engine was knocking around. You can hear the engine actually banging around.
So the mounts went in, and the knocking is gone. But it's still making a knocking sound. When the car is at a stop, and I accelerate (not racing or speeding, just normal), there is knock STILL there. That same sound has been there since I bought the car. It comes form the engine comparment, and I always thought it was the engine. And, it's still there. It's only when accerlating, and I think I hear it whencoming to a complete stop. My brakes my noise (even though my mechanic said there's nothing wrong with them), so i cant tell for sure with the braking think. Any ideas on the sound. I would give more information, but I don't have any more. I hope it's not CV joints or anything like that. Anyway to test?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-18-2005, 10:08 PM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
Re: Still knocking!! WHAT CAN IT BE!!??!!
um i was banging once..... scared the shit outa me but is was the ic pipe hitting at idle make sure there is nothing moving around in there
1990 Mitsubishi Eclipse GSX
1995 Mitsubishi Eclipse GS-T (SOLD)
2002 VW Jetta 1.8T
Old 02-18-2005, 11:18 PM
macder macder is offline
Send a message via MSN to macder
Check your lower control arm bushings. This is a possible cause if your hearing knock when u accelerate and brake.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 02-19-2005, 10:23 AM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
you can also make sure that your exhaust isnt hitting anything. if i remeber correctly theres a recall on balljoints or something on the 2g's. call your local mitsu dealer give them your vin number and have them look up whether the recalls were done on your car. if they havent been done take it in and get em done. most of them should be free and the ones that arent are the stupid crap that doesnt matter.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 02-19-2005, 10:56 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
its a knocking, or a ticking?
DSM geek
Old 02-19-2005, 11:07 AM
kjewer1 kjewer1 is offline
AF - Advisor
The balljoints could still need to be done again, even if the recall was done. And the dealer still has to do it. Safety recalls dont expire, no matter what they try to tell you. Mine were done a few times.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-19-2005, 11:17 AM
do they still replace them for free when you are professionally drag racing the car?
-1stGenRocks-
Old 02-19-2005, 04:13 PM
GSTRacerNVUS GSTRacerNVUS is offline
^^ I doubt it. They didn't want to replace mine even when I don't. I went to a place and had them do a rebuild on my axle ($85.00), and it went away.
I just have a uncompetent Mitsu. dealer.
97 Eclipse GST MT
Race Every Day Like It Will Be Your Last.
My one insignificant mod: Dump Tube - CUT
Old 02-19-2005, 04:58 PM
AF - Advisor
Yes, they do. They dont have a choice. If any dealer refuses to do a safety recall, contact the NTSB, who enforces these things. And there was more than one recall on the 2g balljoints. They even recalled the recall, because it was still a piss poor solution (slopping some tar on the boot).
But who says I professionally race? I just tool around at the track on friday nights...
Kevin Jewer
Old 02-19-2005, 09:43 PM
david-b's Avatar
Dave is THAT guy
Cool. I'll have to check out the dealer. I dont know what was done to it... so Ill go there during the week. So even if it was done, I can get it done again? What exactly was recalled? Is there documentation on this?
75 Monte Carlo
Old 02-19-2005, 09:48 PM
Do a search here http://www-odi.nhtsa.dot.gov/cars/pr...callsearch.cfm It will list every safety recall
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 02-20-2005, 05:07 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
How do you tell if your ball joints are bad? Can you just call up the Mitsu dealer and ask if there are any recalls on your car and tell them to perform them all for free?
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 02-20-2005, 03:53 PM
AF - Advisor
The test is to lift UP on the tire, and watch the boot. If the joint expands, it could be bad. Spec is some fraction of a millimeter. If it fails this test, it MUST be replaced, free of charge. Its not your fault the joints fail, and it could kill you. Thats what safety recalls are for, to make manufactures pay for thier stupidity If the recall wasnt done, and the joints arent bad, they are not going to replace them. I like to check mine every so often. USually during a tranny swap, which I do quite frequently unfortunately, but I've got the front end lifted and I'm unbolting the lower lateral links anyway... If they start to look questionable I just take it in to the dealer and they replace them if they fail the test.
Edit> also keep in mind that the techs like to do these recalls. If I remember correcly they get paid almost 2 hours for the job. It takes about 10-15 minutes. These are the things that bring in the money for flat rate techinicians. My brother works for a mitsu dealership, and would do these all day if could.
Kevin Jewer
Old 02-21-2005, 02:52 PM
david-b's Avatar
Dave is THAT guy
My lower lateral control arms got replaced about 5 months back because the wheel was practically lifting up out of the boot. That was kinda pricey, and I didnt know about the recall. My dad mentioned that some places like to pay for the work that was done. Is there anyway I can get my money back?
75 Monte Carlo
Old 02-22-2005, 03:35 AM
AF - Advisor
If you still have the reciepts I believe you can. But sometimes Mitsu requires the dealer to save the warrantied parts, not sure how that will affect you. Dealers are rated from A to D, the worse they are the more hoops they have to jump through to get mitsu to actually warranty the part. They may change it for free, and not get paid by mitsu. Sucky. At any rate, I would try it, can't hurt.
Kevin Jewer
