| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
One problem
The oil pan bolt on my Eclipse is stripped. The threads internally are stripped not the head of the bolt. I was not able to get it off no matter what I tried and I used a bunch of techniques. Such as vice grip, pipe wrench, screwdrivers you name it I tried it. All I want to know is:
Is it possible to drill a hole through the oil pan bolt? If yes I assume that there would be no sparks or risk of fire, just metal shavings. IF NOT Could I get the Oil out another way like, sticking a tube down the oil dipstick and using suction to get it out? IF NOT That I am open to any suggestion but I would just like to know about the drilling. |
Re: One problem
if the threads internally are stripped then the plug will fall out. explain why you think the threads are stripped? does the plug turn?
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
The only reason i could see you might drill it out would be if you broke the head off the bolt...other than that, drilling is a no-no.
1991 Plymouth Laser RS Only sat for a few years.... |
