| Off-Topic Talk about anything other than cars. |
What spark plugs to use
Ok i just got an MSD coil pack and magnecore wires. What brand of spark plug should i use that would work best with those? any body recommend anything please?
Re: What spark plugs to use
ngk
2006 Isuzu I-280 (Colorado/Canyon Clone) AR 15" Baja's K&N FIPK |
yep NGK is what i hear too. whats wrong with Bosch though?
NGK BPR6ES if stock, 7ES if modified.
Platinum is a shitty conductor, copper a shit load better. Platinum is supposed to last longer, however I had them in my car for a while and after 2-3k miles they started misfiring. Bosch and DSM just don't go together
For Sale 98 Eclipse GS, 5 spd |
I guess that would depend on whether it was turbo or not... I think. Cause, the turbo eclipse requires colder spark plugs. I'm not too sure about non turbo.
Is NGK a colder spark plug?
97 Eclipse GST MT ![]() Race Every Day Like It Will Be Your Last. My one insignificant mod: Dump Tube - CUT |
The brand has noting to do with colder and hotter plugs, each brand has its own range of plugs that are colder and hotter. For example NGK does it like this:
NGK BPR6ES The 6 is what heat range the plug is.. If you goto 7 it will be colder If you goto 5 it will be hotter
I can tell you that Bosch platinum plugs run fine in a non turbo 1G DSM, no reason they won't run well in a 2G. I'm using the multi-tip, which are Bosch's best. My first set lasted over 100,000 miles and could have gone longer. I've never had a problem with misfiring, at least not due to the plugs.
Mark |
Well I have had a bad experience with Bosch and I know others have also. NGK's are a LOT cheaper, I usually change them every oil change to every other oil change.
ngk iridiums
![]() Don't act like you don't love it.
503/2000 |
No platium 100,000 miles for turbos. Bad JUJU.
NGK Irridium. |
I have the NGK R's and they seem pretty good... gonna try the bpr7es soon... I tried to get bosch platinum 4's but they don't allow the plug boot to snap in... from the "seat" to the top of plug isn't long enough for plug wire boot!!! I tried the platinum and it ran shittier than the old ngk-r's that came in car when I bought it!!!
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
wait so i should just use NGK's for my Non turbo? And get them at auto zone right are there different types? Also what size wrench for the spark plugs cause i forgot
Also i heared that single tip is still the best those multi tip and tripple and the new 4 tip spark plugs all suck is this true?
