Door Locks Reversed
96 LHS door locks work in reverse. I press up to uplock the doors and they lock...vice versa. I noticed this started after I replaced the battery. Also a little background the AC/Heat control started acting up (also the cluster stopped working and the airbag light would alternate with the check engine light) and I took it to the delearship to have the problem looked at. They said that the BCM went bad and needs to be replaced. Long story short and $550 later all work except the AC HEAT CONTROL. The AC Heat control cost 575 installed. Has anyone had the locks reverse happen to them?
