Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
Old 12-21-2004, 05:23 PM
sweendog48 sweendog48 is offline
Clutch (pedal) problems
I have a 94 EX w/ a 5 speed.
I haven't had any problems with it until Sunday. Saturday it was fine (it was raining the time I arrived home). Sunday we had a big snowstorm and temps about 5 degrees. I went to move the car so I could shovel the drive ( after I pried the door open) I realized the clutch was on the floor. I could start it but couldn't get it into gear. I thought it could have been because of the rain and the the really cold temps. but today it got up to 40 and I ran the engine for about 45 mins thinking if something was frozen it should lossen up, but no luck. The clutch pedal still sticks to the floor. From searching this site I know this is a hydraulic connection. But really not sure where to start looking for a problem.
ANy ideas?
Thanks
Old 12-21-2004, 05:49 PM
Igovert500's Avatar
Igovert500 Igovert500 is offline
blue + red light magnet
Re: Clutch (pedal) problems
Wait...it is stuck to the floor, or you can lift it, but it just falls back down...if it is the 2nd, and you have no pressure, then you got a leak in your hydraulic system...check master and slave cylinders.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Cusco front + rear strut bars
-Greddy type-s
-ATR downpipe
-no cats
-15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly.
Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical.
Old 12-21-2004, 06:01 PM
Re: Re: Clutch (pedal) problems
I can lift it back up and it will stay up. There is spring that keeps the pedal up, but there doesn't seem to be any resistance when I push the pedal back down.
I will check the master and slave cylinders though.
Thanks
Old 12-21-2004, 06:33 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
there may have been enough moisture in your lines to freeze and burst when it got really cold out that night.
Old 02-01-2005, 05:29 PM
Smeee's Avatar
Smeee Smeee is offline
Well considering you didnt post whether or not you got this fixed imma assume ya didnt. This happened to my car, and at first it was the master cylander, i had a leak riiiight where the master cylander goes through the firewall. Then about a year later my slave cylander went, i cannot really remember the symptoms when that happend, buuut it was obvious that was the problem b/c the rubber around it was ripped and leaking fluid everywhere. I'm sure you ahve fixed it by now, buuut in case ya didnt or if somebody else has this problem its good to know. =)
