My truck starts fine but once it gets warmed up and you hit the gas my oil pressure drops to zero and the oil light comes on. then when you let off gas to make a stop or slow down truck dies and the oil pressure comes back up also when you let off the gas. it restarts easy after dieing but need to know what is wrong with it any Idea??????
Re: Re: 97 dodge ram 1500
yes the dip stick shows it is full
it is a 318 with a 129thousand miles on it
we did a code check on it and it came up with a code 32. Also oil on dip stick has a gas smell to it and seems to be over full now
Gas in Oil
Sound Like you have bad rings. Looks like a engine rebuild will be needed.
Including Heads rebuilds also. |
Sounds about rebuild time. The oil pressure could surely indicate worn main and rod bearings. Gas in the oil would be from bad rings and could be thinning the oil enough to cause the loss of oil pressure to be amplified. A basic rebuild kit comes with everything you need to refresh the motor shy of the machining of the cylinder bores.
