Clicking in engine 95 trooper
we were changing the plug wires in a 95 trooper and we couldnt tell if we were putting them in the right place, well we heard a ticking noise when the engine was started but couldnt remember if it was there before, is this normal? if not, whats wrong?
Re: Clicking in engine 95 trooper
specifically what area of the vehicle is the ticking comming from I would assume engine but top bottom front rear NEED MORE INFO
its like a time bomb tick sound, it sounds like its coming from the mid right section where the plugs go
Ticking Noise in Engine
Early and mid 90's Troopers were notorious for having stickign lifters. I was told to run good synthetic and a mobil 1 filter. I have go 230k on my 95 trooper. Replaced the lifters once. Runs like a champ.
Common problem, do a search for TSB's on the internet, maybe on this site, you'll find it. Try some "Seafoam" in the oil for a while, flush, then go with a low cold-weight synthetic (indicated by the first number) like 0w-30 (Mobil-1 in the tsb), 5w-30, 5w-40, etc. Avoid 20w-50 like the plague! I've had good luck with 5w-30 Mobil 1 and Rotella T Synthetic 5w-40.
I have a 1994 Isuzu Trooper and had a clicking (very loud), it was the timing belt tensioner. Check yours out before someone has you replace the motor. Good luck!
Re: Re: Clicking in engine 95 trooper
