Go Back   Automotive Forums .com Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-14-2005, 11:35 AM   #1
germjoe
Send a message via Yahoo to germjoe
Unhappy Left turn signal dont work pleade help
I have a 99 Gand Cherokee and the left turn signal dosent work. I put a new turn signal switch in and no help. The indicator dosent come on in the dash either. Could it be a bad ground or a broken wire? Need help I dont want to get run over. Thanx
germjoe is offline   Reply With Quote
Old 01-14-2005, 11:51 AM   #2
Ironic
Re: Left turn signal dont work pleade help
Did you change out the turn signal flasher? I think you can swap it out with the hazard flasher to test it. If that don't work, try taking out the bulbs 1 by 1 and check for 12v at front and rear.
Ironic is offline   Reply With Quote
Old 01-14-2005, 02:17 PM   #3
germjoe
Re: Re: Left turn signal dont work pleade help
Thank you for the advice. My friend who is a mechanic also suggested the same and I also purchased new bulbs and tried that. My friend said there might be a left and right flasher but I contacted a dealership and they said there was only one turn signal flasher. But if you can get your head up in there I noticed there was 2 silver flashers. My friend said the other one might be the 4 way flasher he was not sure without looking it up in a book. I have to run to town and grab a flasher and I am going to try and install it this afternoon.
Old 01-14-2005, 05:54 PM   #4
JUSTJEEPS
If one turn signal works its not the flasher.
JUSTJEEPS is offline   Reply With Quote
Old 01-18-2005, 06:08 AM   #5
4x44mud
I have the same problem except it's intermittent.
Thoughts?
4x44mud is offline   Reply With Quote
