Service Soon/Trac/ABS on
I got all three lights but it runs and drives fine. i done some research and figured it it is the bearing or wiring-or speed sensor. Now how do i find which wheel it is? Also any recommendations on the replacement part as far as where to get and price?
Re: Service Soon/Trac/ABS on
Get the Code read so you can find out which sensor it is. As far as replacement just get it replaced, because sooner or later the sensor is liable to go out again. I’m on my second set of wheel sensors in 2 years.
Has anybody ever had any problems with their rear wheel sensors? |
Code read...
I took it to a shop to get the code read and they said it did't have any code being put out. Is there some way I can check the sensors with an ohm meter?
i had this same problem...and they told me that fuel pump regulator switch went out...so they replaced it and told me it was fixed.
but about 2 weeks later it came back on. but i dont understand it because it only comes on every now and then, its not an every day thing. |
For those lights to come on there has to be a code, other wise the lights wouldn't come on, unless maybe something is wrong with the computer. My first time I took my 99 to a shop the guy’s scanner couldn't communicate with my computer because his scanner was outdated. I would at least try taking it somewhere else just to make sure.
It's the one of the wheel bearings or hub assembly that is bad.
Jeremy |
I dont know if this will help any, but I got an ABS and Trac Off light pretty constantly about a month ago... at first I was worried that it was going to be a bearing or speed sensor, or soemthing expensive to replace. At the time, my tires were nearly bald, and I had very little tread left on them. I got new ones (BFG Traction T/A), which had a higher speed rating, but since then I havent had the problem at all... I figure that maybe my sensor was just slipping up because the tires had very little traction... so if yours are pretty low on tread, it may be that...
