Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 12-06-2004, 05:49 PM
chas638 chas638 is offline
Send a message via AIM to chas638
Ignition Key
Help,
I have a 1990 Honda Accord. When the weather is cold, I can't get the ignition key out for about a minute, sometimes longer. I hear it clicking as I push it in but can't turn it enough to remove. It's winter in NY and I'm tired of sitting in the car.
Thanks,
chas638
Old 12-09-2004, 04:08 PM
94hondaacc 94hondaacc is offline
change you ignition switch. sometime too much weight on your keys damages the switch over time.
Old 12-11-2004, 02:22 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Ignition Key
the teeths in the ignition may be damaged or your key is worn not allowing enough contact.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 01-04-2005, 07:48 PM
SANDUNGERO24 SANDUNGERO24 is offline
Re: Ignition Key
Wd-40
Work Fine
Old 01-07-2005, 09:12 PM
riccimangan riccimangan is offline
Re: Ignition Key
if yours is an old key, what normally happens is that the shoulders(the shoulders stick out to stop the key from going in to far) of the key wear down, causing the key to become inaccurate and catchy and makes it difficult to copy the key, if this is the case try a new key(mine had a code printed into it which helps when copying it). if that doesn't work then it must be the pinns in the ignition, you could have the ignition taken apart and checked but you'd probably get one cheaper in a breakers yard.,.,,,.,
