Jeep Cranks but won't Start
My 99 Cherokee Inline 6 cranks but won't start.
I was in the process of installing a remote starter. Everything worked fine (remote start and key start) until I decided to wire up the parking lights to the remote starter. At that point the above mentioned problem started. Thinking the remote starter was causing a problem, I removed the entire remote starter and put everything back to stock condition and still no luck.
I've done a bit of searching on this symptom (strong crank but no start) and I see talk of the CPS coming up alot. What is the chance that the CPS bit the dust? While wiring the parking lights to the remote starter I had to wire up a relay and I got a spark wire I installed the ground. I'm wondering if I blew something? I've checked all of the colored fuses in the kick panel and under the hood.
