Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 12-29-2004, 10:04 AM
candytangygst candytangygst is offline
Banned
need help installing a mbc on my 2g t25
ok this is making me really mad, i cannot figure out how to get the turbos xs mbc to work on my car i have the stock t25 turbo i disconnected the stock bc and hooked the mbc up how it said in the directions which for some reason it didnt work it still was only hitting about 12 12.5 psi and it should have been putting out 1 psi so if anyone can give me some detailed instructions on this i would greatly appricate it
Old 12-29-2004, 10:37 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: need help installing a mbc on my 2g t25
I can tell you how to install a homemade/JoeP boost controller....I wouldn't think that the xs would be any different.
Before I get to that what did you mean by this statement "it should have been putting out 1 psi"????
You need to remove the lines running to the BCS, but leave the electrical harness plugged in. The side of the MBC with the ball should be run to a T in the line coming off the BOV. The other side should be run to the WG actuator. Then all you have to do is set the MBC. Everyone recommends to start with the MBC backed our all the way and make a pull. Then stop, pop the hood and screw it in all little....repeat. Also, if you are using the stock BOV you may want to consider upgrading, it leaks. Enjoy.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 12-29-2004, 10:56 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Follow directions. Adjust. Done.
Kris
2012 Genesis Coupe 2.0t
Old 12-29-2004, 10:30 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
are you sure you installed it correctly? you have to do more then just bipass the boost control sylinoid.
DSM geek
Old 12-29-2004, 11:08 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
if you did your homework you would know that the Turbo XS is not a good MBC for DSM's. but too late for that. 1 line from BOV, 1 line to wastegate. unplug the BCS hoses and clamp of the one not going to the wastegate. leave it plugged in or you may get a CEL.
Old 12-30-2004, 12:08 AM
Banned
Re: Re: need help installing a mbc on my 2g t25
Ive got a 1g bov on 2.5 in. uicp (oh and i have done my homework i probalbly know alot more than you think i have been studying these things for more than a year i can do a 6bolt swap or rebuild a turbo with my eyes closed (boostedspyder)) I had it backed out 3 turns that eliminates the lag and is suppost to register 1 psi. and do i keep the t to the wga and turbo hooked up or break that and run the line straigh to the wga. i have tryed all these ways and they are not working but i can try again thanks for your help man
Old 12-30-2004, 03:30 AM
metalhedskater's Avatar
metalhedskater metalhedskater is offline
Send a message via AIM to metalhedskater
arent there other ways to installing the mbc? I mean ive done it that way as well when i had to install mine, but isnt there a less accurate installation? Also, yea man you should have just bought a regular mbc off ebay for like 15 bucks and itll do a better job than the xs. If you have the option, i would return it.
99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires
One retarded ass site! Geeeeeeeee
My Car
[url=http://www.myspace.com/nobledsm[/URL]
Old 12-30-2004, 03:35 AM
Re: Re: Re: need help installing a mbc on my 2g t25
Not talking shit or anything, but let me get this correct. You can do a 6 bolt swap and rebuild a turbo with your eyes closed, but you cant install a mbc, theres something wrong with that picture. Just making an observation, thats all!
My Car
Old 12-30-2004, 08:39 AM
Kris
Old 12-30-2004, 08:52 AM
Re: Re: Re: Re: need help installing a mbc on my 2g t25
This is one fucked up post. This is like saying that you can build a house from top to bottom and can't install a mailbox post. WTF. How is this even possible. You think that backing out the MBC is going to give you 1 psi of boost (are you sure you aren't talking about 1 bar)? Eliminate the lag??? Shit, with 1 psi you wouldn't even know that you have a turbo. I am confused : . You researched MBC's for a year and can't get it right? Hell, I researched it for about 5 minutes after I got it in the mail and had it installed in about 30 minutes. One year of research for a 30 minute job, and you still can't get it right? So by that estimate you must be about 70....needing 68 1/2 years to research the 6 bolt swap.
1997 Spyder GS-T
5-Speed
Old 12-30-2004, 08:56 AM
Go here.....
http://www.belitski.com/cars/talonmo...aqhallman.html
It even has pictures!!!!!
If you can't get it right after following these directions you need some help.
1997 Spyder GS-T
5-Speed
Old 12-30-2004, 11:10 AM
Banned
I think it is the bc i have hooked it up like 10 diffrent ways, have it hooked up the same way as my buddy and it is still not doing anything and my mom got me this bc for christmas, and yes me and my buddy are doing a 6 bolt swap on his 95 gst right now and i just rebuild his 14b turbo, but i cant figure out this pos mbc.
Old 12-30-2004, 08:05 PM
holy shit! I think i installed my mbc wrong. Well, i did everything, but unplug the y split which leads to the turbo compressor and the WGA. So what i have is the on hose going teed to the bov and the other hose plugged into the other tee where the WGa and the turbo compressor is. On the site it says to plug the compressor with a plug (which i dont have), and plug the hose from the mbc to the WGA. So should i do this, and why not keep it the same? Why plug the turbo compressor? Thanks in advance guys!
My Car
oh and sorry to invade on your thread here candy, but i thought it might help you as well if you have the same problem.
My Car
Old 12-30-2004, 08:11 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
what you have now is a mbc thats hooked up right but the stock line still opens the turbo
yopu need to plug that hose otherwise your mbc doesnt do anything
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
