Climate control problem
Hey all,
I've got a 98 venture. Recently, the fan stopped working in all postitions, except '5' (high). Also, I can't get the air flow to switch at all-right now it comes out the bottom vents, middle vents, and the windshield defrost vent. Any Ideas? Matt |
Did you ever get your response. I have a similar situation on direction of air flow
Re: Climate control problem
No, I never did get a response, and I still have the problem.
Matt,
Blower problem is probably the "blower resistor". Everything EXCEPT high (5) has to go through there. As for the air flow, there are diverters that sometimes "get stuck" as the car ages or "stuff" gets stuck in the heater/AC assembly. My 2001 has a similar issue right now (which I have NOT attacked yet). There is a control arm on the driver's side of the center console that gets stuck and will not return to the proper position once "dash only" vents are selected. I had to remove the sound panel on that side and give it an extra push to get any air to come out of the "defrost" (windshield) vents. Good luck, Greg A. |
Thanks Greg! Now, if I can only find this resistor. Any idea on where it is?
the resistor is behind the blower on the passenger side. Take out the blower, 3 or 4 bolts I believe, then unhook 2 wires. That's it. I did mine last week in about an hour, and I'm not very mechanically inclined. Cost $50.
Re: Re: Climate control problem
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
The schematic I have shows only lower 4 setting go through the resistor pack. Setting 5 (high) bypasses resistor and applies 12V to the motor (through a relay - also on the resistor/relay "assembly"). I believe this is for my 2001, but it should be similar for other years.
I tried to put the schematic up, but don't know how to insert graphic filles here. Sorry. Take care, Greg A. |
