| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
I was wondering what u guys think would be the safest/most boost i can set my 1g GST to? I got a stock fuel system, K&N intake filter, 2.5" catback exhaust, 16g turbo, Joe p MBC. Stock boost i belive is 9psi, i was thinking maybe 12-13psi??? What do u guys think? Help me out! Thanks...
Re: How much boost???
safest 10psi
best 13psi max 15psi
![]() 1998 Eagle Talon TSi AWD 6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband |
Re: Re: How much boost???
![]() 99 GST/evo 3 16g/3" Catback/Intake w/filter/UICP/1g BOV/Complete prothane motor mount inserts/Boost gauge/AF ratio gauge/MBC/NGK Plugs/HotWires/17" Sport edition fox 5 racing rims w/Fuzion tires One retarded ass site! Geeeeeeeee My Car [url=http://www.myspace.com/nobledsm[/URL] |
With a 190lph fuel pump, you could probably pull 17 psi relatively safely until you get bigger injectors. You try to go any farther and you will become a slave to fuel cut
. Though, I wouldn't do anything else until you get a pocketlogger w/ palm so you can see what's going on. Once you get some injectors, fuel pump, pocketlogger, and possibly an AFC (something to tune with) you can turn up the boost even more . Until then, stick with whatever you're at right now (shouldn't be more than about 14psi).
![]() 95 GSX DSMlink, "50 Trim", and track times coming VERY SOON!
Matt is completely right--get a 1g datalogger ($30 palm, $10 cable, free software download (Tunerstein)), and hook it up. If your timing is getting pulled (i.e. timing drops off lower as rpm increases, instead of gradually rising), then you are knocking, and you want to turn boost down.
Does Tunerstein log knock count in 1g's?
1996 Eagle Talon |
Thanks guys for your inputs!
I also had another question....I was also wondering how would you know exactly how much boost you are pushing? I've noticed that on 4th and 5th gear boost gets up higher around 10-11psi. From 1st gear it's like 5psi, 2nd is like 7psi, and 3rd is 8-9psi. So i don't know which one to go by...My buddy told me to foor it on 5th gear and see what psi it hits then that would be how much you would be boosting. Is that true??? BTW i have an Autometer boost gauge....Thanks! |
Umm i dont think you need to fllor it on fifth gear...i mean ive seen the max boost on my gauge when i floored in 2nd gear...so try second gear and see what boost reading you are getting...
i have a 90 laser rs turbo, except for a kn filter its completely stock; the factory boost gauge hits 13 psi no matter what gear im in.
KN Filter raises some HP/TQ, but you'll need more stuff to make the stock Boost Gauge go higher or prolly a BC. Well, what i thought was that all you needed was just the common stuff
-BC -2.5" to 3.0" piping to exhaust -after market exhaust manifold -new inter cooler pipings -fuel pump -wastegate and you're good to go.....17 to 18? but thats pretty high, im guessing 14-15 psi for daily driver...
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines" --2OF9-- (DSM team specialist) ;D #808/1000 |
forced: keep it at 14psi untill you get bigger injectors. or find the upper psi limits of 3rd and see where you hit fuel cut, then back it off 1/4psi at a time untill no fuel cut.
bad4g63: get an aftermarket boost gauge. then get a boost controller and play with it like that. |
hey the car that i am about to buy is a 91 tsi Awd. and it has enough supporting mods that he drives at 14psi Daily Drivin (i think stock fuel system). Now i have some RC 550cc injectors and a 255 lph Walbro laying around form my old RX-7. I know that i will need a pocketlogger. but how high do you think i can run once it is fully tuned through the logger
make sure that the injectors from the 7 are the right impedence for the talon. some injectors are high impedence some are low and dsm's aren't the same as most cars.
-1stGenRocks- 95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's plans: bastard 20g, water/meth injection NO FMIC |
yea i know that. both cars use low impedence injectors. the 91 AWD talons used low's, Right. and if the connectors arent right i have a guy that i can get plugs from to shap into the RC injectors
so what kinda boost shoud i set it to once tuned.
im not sure. its still the stock turbo right? search around on here some i remeber seeing a list from kevin or somebody about how much boost you can run with different setups.
BTW rewire the fuel pump when you put in the walbro. vfaq.com has directions
