| Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here. |
I just got this gauge, http://cgi.ebay.com/ebaymotors/ws/eB...942426207&rd=1
And i dont know were to hook up the wire that tells how fast your engine is running, i dont know what its called tho. You know what i mean tho right, i have a 1990 mustang Gt. witch wire do i hook this thing to. and the other wire to i dont know were to put it. My hole gauge has 4 wires 1 ground/black, 1 Power/red, 1 Tech wire i think that is what its called/green, and 1 white wire i dont know what this wire goes to ether. please help me. |
Re: TACHOMETER Help
help me please some one.
Re: TACHOMETER Help
any one
Re: TACHOMETER Help
Red is a switced power source. Black in the ground. Green in the Tach lead. White is the illumination wire.
The red wire can be run in line with the fuse box, or do like I did and splice it inline with the radio power wire, which is switched. The ground is any good chassis ground you can find. Green, tach lead needs to run to the negitive side of the ignition could. ![]() White illumination wire can be wired into the fuse box on the headlight fuse, or the headlight switch itself.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
Re: TACHOMETER Help
ok thanks alot
Re: TACHOMETER Help
ok i did that but its not working now.
Re: TACHOMETER Help
What is not working? Can you post pics of the wiring coonections, that would be great help?
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Re: TACHOMETER Help
i got it now it works fine thanks alot.
Re: Re: TACHOMETER Help
