Go Back   Automotive Forums .com Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 12-13-2004, 02:51 PM   #1
FoRCedInDuKsionGsT
Question Boost isn't getting any higher....help
Alright...i just got the JoeP MBC like a week ago and for some reason when i adjusted it to push more boost my boost gauge on shows 11psi after adjusting it so many times. It doesnt seen to get any higher than that. I've turned the knob so many times to get the boost up and for some reason it's not working. I don't even wanna touch it no more because i might be boosting too much and i dont know it. What do you guys think may be the problem? What is your guys input?
FoRCedInDuKsionGsT is offline   Reply With Quote
Old 12-13-2004, 03:11 PM   #2
spyderturbo007
spyderturbo007's Avatar
Re: Boost isn't getting any higher....help
I am assuming you are talking about an aftermarket boost gauge. If so, what did you run before the MBC was installed. Did you eliminate the BCS when you installed the MBC?? Are you sure all of your lines are tight?
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
spyderturbo007 is offline   Reply With Quote
Old 12-13-2004, 06:21 PM   #3
FoRCedInDuKsionGsT
Re: Re: Boost isn't getting any higher....help
Yes, it is a aftermarket boost gauge. I replaced the BCS with the MBC, one line to the wastegate the other to the intake...basically just swapped the two. Would it be possible that i installed it incorrectly? What would be the proper way to install the MBC? Thanks...
Old 12-14-2004, 06:26 PM   #4
FoRCedInDuKsionGsT
Unhappy
Anyone other DSMers have any input??? Come on.....
Old 12-14-2004, 08:33 PM   #5
Scoped_GST
Send a message via AIM to Scoped_GST
ehhh, i had the same problem...EXACTLY, but I knew at the time that the 2G bov is crap and likes to leak. The damn UICP should be here tomorrow im hoping, so I'll let you know how it goes.
Scoped_GST is offline   Reply With Quote
Old 12-17-2004, 06:51 PM   #6
FoRCedInDuKsionGsT
Alright i finally got the boost up and it seems to be boosting properly, but its boosting more than i thought. For some reason when the boost hits 10psi it just suddenly jumps up to 16psi out of nowhere in less than a sec. I was like holy crap!!! so i let off the throttle. I have a JoeP MBC and it is set to 0 so i dont know why im boositing so high if my BC is not even adjusted for more boost. Any of you guys have any idea how to get the boost down? Im only trying to hit 12-13psi on full throttle cause i dont wanna mess things up. Thanks!
Here's what i got under the hood:
-Free mods
-JoeP MBC
-K&N filter
-full 2.5" custom cat-back exhaust
-16g turbo
*keep in mind i have a stock fuel system
Old 12-17-2004, 09:49 PM   #7
guitarXgeek
guitarXgeek's Avatar
Send a message via AIM to guitarXgeek
If you've got one line going from the MBC to the wastegate and one back into the intake (like the stock BCS), then you have it hooked up wrong. http://www.dsmtuners.com/forums/showthread.php?t=105573 <-- That is the proper way to install a MBC.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
guitarXgeek is offline   Reply With Quote
