Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 12-05-2004, 02:34 PM
Noystahz Noystahz is offline
Help!!
OK i have 92 hatch.. i purchased it along time ago and it came wit a cd player deck.. well i wanted to change the dec i jus saw that that last owner that i bought it from cut the dam harness.. well iono y he do that for when u can get a harness from the store and jus mathch the colors.. WELl i dont no how to wire my dec bac becuhz the old dec is out and i was wonderin if its possible if I can buy a whole new Wiring thing the harness tthe stoc one
( sayin as in where can i get it if it possible they seel it)
Old 12-05-2004, 11:14 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
Re: Help!!
go to your local walmart and pick up a plug for your year, and model... and splice them into the existing wires... or you could just go ahead and rewire all the speakers in your car with some high quality wire... if I were you I'd just rewire the whole thing and be a step ahead in stereo mods... although you might want to run all the wires to the rear of the car if you plan to install an amp for your component speakers.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 12-06-2004, 04:46 PM
Re: Help!!
u kno that im talkin about my stoc harness wire that he cut right? not the new harness that connects to that stoc one.. well yea that stoc harness is out and u kno it got diff colors that ar not th same as the harness that connects to the stoc one. be cuhz the stoc harness wire dont got the solid colors..
Old 12-07-2004, 01:33 AM
Re: Help!!
read the print on the wires... they all say where they go... rspkr+, lspkr+ and so (not particularly like that, but just take a close look at the wires...) you can also look at the color code on the bottom of a stock headunit.
Old 12-07-2004, 08:18 AM
xtant's Avatar
xtant xtant is offline
If you are just looking at puting a different cd player in no amps or any thing else. you can pull out each speaker and write down what color the wires are for each one. You might be able to tell which is the positive and which is the negative, if not you will just have to play with it until it sounds correct. The wire harness that comes with the after market radio will have the writings of "left front speaker" etc. Then get your hands on a test light to figure out wich wires are you constant 12v, your ignition that comes on when car turns on, your illuminant comes on when headlights do, and your ground is more than likely black
Josh
Old 12-09-2004, 02:31 PM
1gspot's Avatar
1gspot 1gspot is offline
Send a message via AIM to 1gspot
Re: Help!!
go to the junkyard and cut one out of another car like urs
