Go Back   Automotive Forums .com Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 11-27-2004, 06:44 PM   #1
johnbstl
Unhappy 95 neon. cooling fans run all the time
I think I need to change the thermostat switch, But I can't find it, any help out there ?? Thanks
johnbstl is offline   Reply With Quote
Old 11-28-2004, 11:35 AM   #2
yogi_123rd
Re: 95 neon. cooling fans run all the time
Cooling fans that run constantly could be either a sticking relay (under hood, in a rectangular box by the driver side fender) or the temperature switch (I think it is located at the bottom corner of the radiator - not sure. If not, check around the thermostat area on the engine for a plug with a two wire connector.)
You can check if it is the relay simply by replacing the relay for the cooling fans with another from the relay box (note: The part numbers of the relays in that box should all be the same and swappable).
yogi_123rd is offline   Reply With Quote
