PCV hose broke
1990 3.1
A stalling/idling problem prompted me to replace the PCV valve. The hose, brittle as rock, broke in half unfortunately. I wedged a scissors jack against the firewall to move the engine forward about 5 inches. (That's how I reached the valve in the first place). So I probably have enough arm room to work, butthe hose runs too deep into the engine for me to even feel the end of it. So how do I replace the hose? My Dad thinks I might have to lift off the intake manifold to reach the hose, but I know nothing about cars. |
Re: PCV hose broke
Re: PCV hose broke
No, you don't have to remove the intake manifold, just the plenum. It attaches to the under side of it. Simple to do, just need to get a couple plenum gaskets which are very cheap.
all you need to do is remove the upper intake plenum, it's 9 bolts and a $14 gasket set (fel-pro ms94944). Tip the upper plenum up (so you don't have to remove the throttle body or the coolant hoses that go to it) and you'll see where the pcv hose attaches to the lower intake.
Re: PCV hose broke
Wow! It's really nice to know that I don't have to remove the intake manifold. Thanks for the input!
Re: PCV hose broke
no problem, glad I could help
Re: PCV hose broke
You CAN get away without replacing the gaskets ...if you're CAREFUL!... I did...
And, while I was at it...I replaced the center section of the hose with a short piece of brake line that I bent to fit... At the ends, I used two short, HIGH quality hose pieces... I won't (hopefully) ever have to deal with a broken PCV hose again. Just a suggestion. |
