lift kits
is there any lift kits out there for a 2wd 1987 150 if not then how hard would it be for me to go to a juck yard a get the parts off of one that has 4wd and put it on my truck
![]() Join Date: Jul 2004
Re: lift kits
4wd uses a completely different suspension in front, so getting a 4wd lift won't help. If you want to lift your truck, you should be able to go with taller springs in front and larger lift blocks or more arched springs in back.
Re: lift kits
ok thanks i was talking about putting 4wd in my truck then lifting it
Re: lift kits
If you want to go with 4x4, then you're better off selling your rig and buying one with stock four wheel drive. Installing the capability into a 4x2 is so much more trouble than it's worth that it isn't even funny.
#5 | ||
Re: Re: lift kits
Re: lift kits
how hard is it to replace the leaf springs?
#7 | |
Caution: Monkeys bite!
Re: lift kits
Not easy; I'd go with the previous advice on this one and buy a 4wd. In reference to your other thread about lifting the vehicle, you'll need alot more than shocks to do the 4" lift you're talking about. Check at skyjacker or some other lift kit manufacturer; I don't know if they even make lift kits for 2wd trucks.
(End result: buy 4wd!!) |
