91 Lumina Turn Signal problem
I have 91 Chevy Lumina 3.1L V6 and have turn signal problem. When I switch left or right turn signal, it's lighting but not blinking. But if I turn on hazard signal it's blinkinkg. I have changed turn signal switch and flasher, but the problim is still the same. Tell me what's the going on and what I have to do?
![]() Join Date: Mar 2005
Re: 91 Lumina Turn Signal problem
have you checked the bulbs outside?
sometimes when they burn out they can make the rest of the system go crazy |
the bulbs is OK. Do it have some relay for the turn signals and where it is placed.
I own the same car 91 2 door chevy lumina euro i have the same type of problem when i put on my right turn signal it wont blink unless i hold up on it. it seems the position of the steeringwheel also effects it, however my left turn signal has given me no issues as of yet. i am thinking that i have a problem in the steering column. try holding up or down on it and see if that helps good luck
stupidity should hurt
![]() Join Date: Aug 2004
There are 2 flashers on your car, are you sure you changed the correct one? The hazard flasher is located in the passenger compartment relay center near the glovebox. The turn signal flasher is located under the dash, between the steering column and the radio.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
Calitas, your problem is the turn signal/multifunction switch assembly.
