Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 10-27-2004, 07:14 PM
toverby toverby is offline
89 civic w/ b16a axle problem
I have installed my b16a in w/ no problems except the axles. I was told to buy 1990 integra axles and they would fit. I bought some from autozone. They do fit except the end that goes into the wheel hub is to big for the splinned hole. Do i need to install integra hubs also. I have not heard anyone say this is neccessary.
Old 10-28-2004, 12:58 PM
DBISIS DBISIS is offline
I beleive the axels you needed were 91 Integra axels.
Old 11-03-2004, 01:53 PM
4d4g-808 4d4g-808 is offline
1991 acura integra axle
Old 11-03-2004, 02:43 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
was your stock civic a 4 speed ?
Team Lonely Drivers
Old 11-04-2004, 01:59 AM
ad_rock82 ad_rock82 is offline
1990~1993 teg 1.8 (not 1.7) axles will work as long as your car is not the basic civic...if it was a DX, or Si then the diameter of the hub to the axle shouldn't be a problem...you may need to remove the dust seals on the hub end of the driveshaft and in the hub itself. you will probably also need to disconnect the tie rod ends to get the extra travel to clear the hub assy around the end of the shaft as it is a real tight fit. the teg axles are almost too long, but they work fine.
Old 11-04-2004, 08:47 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Re: 89 civic w/ b16a axle problem
yea, those r the right axles, as long as you dont have an HF or STD crx/civic.
Stable Of Cars I have Owned:
1991 Honda CRX
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 11-07-2004, 12:05 PM
o14liquid o14liquid is offline
Send a message via AIM to o14liquid
hey, sorry to post a question in someone else thread but it sorta went with the information i needed.
If i were to get a b16 engine, and get the 91 teg axles, would i have to get a different set of hubs? my car is a 91 civic std
Old 11-07-2004, 09:08 PM
yes with a std you will need new hubs, get dx or si hubs
Team Lonely Drivers
