Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-29-2004, 06:16 PM
jimo1948 jimo1948 is offline
no high beam headlights
I have a 1998 Jeep Grand Cherokee and the headlights do not work on high beam. The low beam works fine, but when you click to change to high beam there are no lights. The high beam indicator doesn"t illuminate either. I have tried replacing the bulbs and dimmer switch and no help. Is there a relay or something that makes sense. Thanks Jim O
Old 10-29-2004, 08:15 PM
ChadEbert ChadEbert is offline
Re: no high beam headlights
Check the relay, refer to owner's manual for location.
Old 10-29-2004, 08:38 PM
Re: Re: no high beam headlights
that is my problem, my manual doesn't show one
Old 10-29-2004, 09:23 PM
mkvapil mkvapil is offline
Did you check the fuses?
Old 10-30-2004, 03:45 AM
Cam7 Cam7 is offline
Had that happen on my 93 XJ No Brights. Thought is was the dimmer switch checked out fine. The Problem turned out to be in the wirring harness. A juction block was corroded and wouldnt let the Brights work. The block was located under the Air Cleaner Box. Not sure if yours is same? My 96 ZJ is about the same place.
Old 10-30-2004, 08:48 AM
fuses(2) 30 amp under the hood and 10 amp under the dash are good
Old 10-30-2004, 11:26 AM
no such luck on the junction box. any other ideas
Old 10-31-2004, 09:17 PM
Audiobahn77 Audiobahn77 is offline
http://www.autozone.com/servlet/UiBr...3d80153e8f.jsp
The very bottom ~ Fig. 50 The diagram shows two 15A and one 30A. I would check to make sure you are checking the right fuses. If you have a multimeter, check your voltages and your grounds to find out what is not getting power or ground. I wish ya the best of luck finding it.
Old 11-01-2004, 04:24 AM
Is your dimmer switch activating all the way? Some are adjustable to let the rod push in the switch all the way. With a test light or DVOM check to see if you have any volt comming out of the bright side of the switch. If not run a jumper to the hot side of the dimmer to the bright wire,and see if you have brights. When you said no luck on junction was it not under battery box or was the harness OK?
Old 11-01-2004, 06:23 AM
it was not under the battery box
Old 11-01-2004, 10:24 AM
Caribbean ZJ Caribbean ZJ is offline
This Happened to me before (93). Changed headlight assembly (needed new ones). The new ones came with new bulbs.Did u try getting new bulbs or checking the bulb base for corrosion. When lights dont work bulbs are the first to be checked.
Old 11-01-2004, 01:01 PM
changed both bulbs. no change. both high beams don't work and the dash indicater light doesn't come on.
Old 11-02-2004, 05:32 AM
Try running down circuit L3 from the Body control module to the DayTime Running Light Module located under the power distribution center on right fender under hood. Circuit L3 on some JGC powers the High Beam. Also check fuse 13 in the PDC.
Old 11-04-2004, 05:01 AM
According to my manual the harness junction is s107 is located in the area of the Air Box left front corner of engine compartment.
Old 11-04-2004, 09:04 AM
I found the harness, but I didn't see a plug that would arouse suspession. In your manual, did you see a relay, or specific fuse that could be the culpret. Do you know where I could find a good electric diagram?
