Go Back   Automotive Forums .com Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-03-2004, 03:38 PM   #1
crabby760
car wont rev past 4k rpms???? help
hello my friend has a 98 accord lx 4 cylinder 2.3 vtec
it has i/h/e 3 piece pulley kit......
car has bout 72k on it..
all the sudden it wont rev past 4k rpms what could cause this?
someone let me know
fuel filter maybe im not sure? let me know ur thoughts....
crabby760 is offline   Reply With Quote
Old 11-03-2004, 03:41 PM   #2
civickiller
Send a message via AIM to civickiller
does he hit a rev limiter at 4k or does it just stop reving at 4k like how if you part throttle and hold the revs at a certain rpm ?
Team Lonely Drivers
civickiller is offline   Reply With Quote
Old 11-03-2004, 03:44 PM   #3
crabby760
not sure yet... but wat would be the problem if it did hit a limiter at 4k and wat is the problem if it just wont go past 4 but doesnt hit a limiteR?
Old 11-03-2004, 04:24 PM   #4
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
Re: car wont rev past 4k rpms???? help
ECU limp mode? Is he throwing codes?
CivicSpoon is offline   Reply With Quote
Old 11-03-2004, 04:38 PM   #5
crabby760
no engine light.... and he said its like hitting a limiter... but not as bad... and if he downshifts it will go past 4 but no power then it revs down to 4 again.....
Old 11-03-2004, 05:40 PM   #6
civickiller
check for codes, just because theres no CEL on doesnt mean there isnt a code in the ecu
Team Lonely Drivers
Old 11-03-2004, 06:25 PM   #7
crabby760
but are there any other reasons thiis can happend.... besides the ecu?
Old 11-03-2004, 06:26 PM   #8
crabby760
his car is all stock just i/h/e and pulleys... why would the stock ecu mess up...
Old 11-03-2004, 07:15 PM   #9
CivicSpoon
There is no Spoon
CivicSpoon's Avatar
I was thinking more along the lines of a sensor malfunction, that may cause the ECU to make the ECU go into limp mode and pretty much make the car a dog. Maybe check the wiring of the vtec solenoid. I'd still think that any way it's throw a code.
Old 11-03-2004, 07:34 PM   #10
crabby760
so besides the ecu issue... is there any other problems that could cause this to happend.... if so let me know
Old 11-03-2004, 08:11 PM   #11
civickiller
headgasket
Team Lonely Drivers
Old 11-03-2004, 08:27 PM   #12
crabby760
any other things we can check?
Old 11-03-2004, 09:00 PM   #13
Prelude707
Send a message via AIM to Prelude707
My 2k Prelude is experiencing the same problem except at 6500ish rpm. It'll let me pass that number once, maybe twice, but after that it locks me out. I don't really know the problem.
I am throwing a CEL, which I believe is Vtec System Malfunction. I believe it might have something to do with my VAFC changing the VTEC engagement point to 4k. But the car (and VTEC) seem to be working fine. So I'm confused since I've never heard of anyone throwing a CEL for that.
Also I'm experiencing the Cold Air Bypass Valve bouncing idle problem. I don't know if this has anything to do with it.
I'm putting in my OBI ECU and fixing the CABV this weekend. If that doesn't fix the problem I'm gonna start to worry.
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Prelude707 is offline   Reply With Quote
Old 11-03-2004, 09:34 PM   #14
crabby760
can someone tell me where the ecu is located on a 98 accord... please thanks
