Old 10-24-2004, 12:02 PM
Prelude707 Prelude707 is offline
Send a message via AIM to Prelude707
Question WTF is wrong with my clutch?
I got an ACT extreme pressure plate w/ street disc and streetlite 12.5 Ibs flywheel. Installed it with a buddy roughly a month ago. We seemed to do everything right since my friend has put in a ton of clutches before. When I'm punching it and hit 6100-6200 rpm the clutch will just slip. It happens in every gear, and every time at about the same rpm. I'm kinda pissed because I just lost a race because I couldn't use my big power rpms. Can anyone help me?
2000 Honda Prelude
Mod list-
AEM CAI, AEM underdrive pullies, AEM FPR w/fuel rail, AEM brake pads, Apex'i N1 catback exhaust, Random Tech Hi-flow cat, Autometer fuel pressure & A/F ratio gauges, Apex'i VAFC(dyno tuned), ACT Xtreme pressure plate w/street disc and streetlite flywheel, Zex wet shot w/dual bottles and purge, Neuspeed front strut bar, VIS EVO CF hood, Honda Access door sills, NX bottle warmers, Lean Racing short shifter
Soon to come-
17" wheels, ES motor mount inserts
Old 10-25-2004, 12:29 AM
G3_preludeSI G3_preludeSI is offline
Send a message via AIM to G3_preludeSI
Re: WTF is wrong with my clutch?
the higher grade performance clutch you get, the longer they take to break in, w/ the clutch disk you had, it could take up to a year to get fully broken in......if not then take it out and check the whole clutch system and see if there is any problems in that area
Old 10-25-2004, 11:22 AM
I drove the car for 800 miles before even revving over 3500 rpms to break in the clutch. And it has close to 3000 miles on it now. So I don't think that's the problem. I'm stumped.
2000 Honda Prelude
Mod list-
Soon to come-
Old 10-25-2004, 10:23 PM
well i have no idea then, just take it all apart, i kno its time consuming, but just do it, and check everyting.....ur bownd to find it, its prolly glazing on the flywheel, its rare but it happens, the same thing w/ brakes......just check
Old 10-26-2004, 12:04 AM
Update: I found out that I can rev the car past the 6100 mark once or twice. But after that it will start slipping. Don't know if this information helps locate the problem. I'll probably be ripping apart the tranny one of these weekends, but just in case someone can point me in the right direction. Thanks.
2000 Honda Prelude
Mod list-
Soon to come-
