suggestions and advice on a certain setup...
ok this is what i plan to run on my 1996 Teg LS b18B1...or am thinking about running unless somethin better comes my way.
i want to get a full motor rebuild, thicker and all new gaskets, forged internals, with the compression ratio staying around 9.2 . gettin basic bolt ons, new cams, and a head rebuild, maybe a P&P. And then later down the line going with a supercharger. i know the motor will be able to withstand this, but will it also be able to handle around a 50 shot of nitrous every now and then at the track, with the bolt ons, cams, SC, with the forged internals and all? thanks everyone.... |
Re: suggestions and advice on a certain setup...
yes, especially with the engine built.
wel like some of my fellow animals have said in the past, if you are worried about nos messing up your engine, try a cheap alternative, like propane
Re: Re: suggestions and advice on a certain setup...
also, about how much power would i be putting to the wheels, without nitrous, after a proper dyno tune? at least 220 whp?
variables come into play on that. like what type of cams are you going to use? how much boost? and with the common bolt ons you should be hitting close to that number. not really quite an exact science.
93 teg LS B20B![]() ACT Performance Flywheel AEM CAI DC Sports Stainless Steel Header G4 High Flow Cat GReddy MX Cat Back Exhaust Skunk2 Racing Chip Lots of interior goodies |
i want to use crower stage 2 cams, and the boost will stay around 8 psi. not sure of what fuel management yet. |
forget SC, go TURBO!!!! theres only so much u can do with a supercharger. the oppurtunities of turbo are much higher. a 9.2 Compression ratio will be fine. and if u get the stage 2 cams (the crower 62403's) then ur compression will go down even more. u also need to get a set of cam gears to tune those cams once u install a sc or turbo.
if ur build n the motor now w/o boost n the motor, that 9.2 compression ratio is gonna be horrible when u install the cams. if u dont mind have n a slow car in the mean time b4 u go boost, then go ahead. i would just save up and do it all in one shot
www.MEDIUMRACING.com
Agreed.
hows this..LS's are know to be able to withstand up to 11-12psi on STOCK internals.
Why are you needing a 50 shot of N20? You have boost, you could always increase the boost, especialy sense you are bulding the internals. With a well built bottmend and tuning you could push 12-15 psi daily and 18-20 ish at the track. That will be more than enough power to break axles, toast the clutch, and completely roast tires. My
but could i run 12-15 pounds daily/ 18-20 track on a built bottom end, with a CR of 9.2? |
Re: Re: Re: suggestions and advice on a certain setup...
