Old 10-20-2004, 09:50 AM   #1
robsieb
Question Here's another 02 Blazer question.
How do you replace a burnt out light in the door lock switch? Do you have to replace the whole switch or just a bulb. In either case, is there a special tool to remove the wire connectors?
robsieb is offline   Reply With Quote
Old 10-20-2004, 01:49 PM   #2
hunter01
Re: Here's another 02 Blazer question.
You should be able to carefully pry up on the front edge of the switch plate, and then slide the assembly foreward and lift to see what the parts look like. GM does make an electrical connector removal tool,not sure of the part number. You should be able to use a small flat tip screwdriver to gently pry back the plastic retainer to remove the connector. PS. Disconnect neg batt terminal before working on electrical components. Hope this helps.
hunter01 is offline   Reply With Quote
Old 10-20-2004, 02:33 PM   #3
hunter01
Lisle makes an electrical connector seperator Part #13120
Old 10-20-2004, 02:46 PM   #4
robsieb
Thanks for the info. Any ideas on if you can change just a bulb or the whole switch?
