Go Back   Automotive Forums .com Car Chat > Jeep > Wrangler
Old 11-11-2005, 07:34 PM   #1
The Stever
Transfer Case Lowering
How low can I lower the transfer case with lowering bars to maintain the stock drive shafts when doing a SOA with 3.5" lift springs?
Thanks!
The Stever is offline   Reply With Quote
Old 11-12-2005, 06:36 AM   #2
Ray H
You cant lower it enough. Thats about 9" of lift. No way your stock rear driveshaft is going to work and probably not your front either.
Ray H is offline   Reply With Quote
Old 11-16-2005, 08:03 AM   #3
scoutinkeith
scoutinkeith's Avatar
Send a message via AIM to scoutinkeith
Re: Transfer Case Lowering
I'd have to agree with Ray H, a spring over with 3.5" springs is going to be way to much lift to use the stock driveshafts, even if you did lower the T-case. and unless you also lower the engine, you can only drop the case a little over 1" before you run into clearance problems with the engine and fire wall.
if you are definatly going to go with that much lift, I think you best bet would be to get a longer front shaft, and a SYE (Slip Yoke Eliminator) and CV shaft for the rear.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
scoutinkeith is offline   Reply With Quote
