Old 12-11-2004, 04:04 PM   #1
jmcondra
'98 Pathfinder - Torque Converter Clutch
I am having a problem with the torque converter not locking when I'm at speeds above 60 MPH. This is causing the CHECK ENGINE light to come on with a P0744 code. "Torque Converter Clutch Circuit Intermittent"
I have replace the TPS and adjusted it over and over. I have replaced all of the AT fluid 2 times and I had the filter cleaned/replaced a year ago.
So, I cut the wire on pin 5 of the Transmission Control Unit and connected in a 2 position push button switch. In one position, I give 12 volts to the Tourqe Converter Clutch solenoid. In the other position, the TCU can control it.
I test drove it for 30 minutes. When I push the switch to lock up the TCC, it stays locked up, even at high speeds. In the other position, it won't stay locked up at high speeds.
So, I think my TCC solenoid is good.
Any other ideas???
1998 Nissan Pathfinder Automatic 4WD
197,000 miles!!
I do have an ATF leak, but I think it's an unrelated symptom.
Thanks
jmcondra is offline   Reply With Quote
Old 12-16-2004, 04:45 AM   #2
WhiteCavaliac
Send a message via AIM to WhiteCavaliac Send a message via Yahoo to WhiteCavaliac
Hi- I have never heard of a problem like that but what your saying is you can lock your converter at any time? Even at low speeds, like 30-40mph?
I was also wondering how your pathfinder held up for the past 197,000 miles, any major problems? I've got a 2000 QX4 w/62,000 miles. Had it for about 5 months now...anything I should lookout for?
WhiteCavaliac is offline   Reply With Quote
Old 12-17-2004, 05:19 PM   #3
infinman
When you adjusted your TPS did you reset closed throttle position switch,if tcu does not see proper closed throttle position, it will not command TCC operation
infinman is offline   Reply With Quote
