Go Back   Automotive Forums .com Car Chat > Honda > Integra
Old 10-11-2004, 03:44 AM   #1
B18c_all_da_way
All Moter N/a Gsr ????
look guys i need your help,I need some help on what are da best things to do to my gsr ,cus i want to go N/A all moter ............???? thanks
B18c_all_da_way is offline   Reply With Quote
Old 10-11-2004, 03:18 PM   #2
LSfrankenstein
Banned
Re: All Moter N/a Gsr ????
going N/A pretty much means your going to be rebuilding your entire motor. You should get a stroker kit with a deck block and some CTR pistons and CTR cams and beefy rod bolts. oh u'll need new valve springs to prevent valve float and u can get like a skunk2 piggyback ecu to raise ur rev limiter past 8100
LSfrankenstein is offline   Reply With Quote
Old 10-11-2004, 07:34 PM   #3
b18 ls
Banned
b18 ls's Avatar
Please do not listen to any of lsfrankenstien's post. He is here for comical reasons only. After you've gotten intake, headers and exhaust, you should get new cams, cam gears, and valve/valve springs. I would always recomend skunk2 camshafts for a vtec b18, or b16. After that, you can get new pistons.
b18 ls is offline   Reply With Quote
Old 10-11-2004, 07:56 PM   #4
B18c_all_da_way
thanks
yo thanks for your help man rescpect ..
Lex p.s i'll link yu after i do all thoes things , to see whts next
Old 10-11-2004, 11:45 PM   #5
LSfrankie
Banned
LSfrankie's Avatar
that up there was a serious post btw. how is it bs?
LSfrankie is offline   Reply With Quote
Old 10-11-2004, 11:58 PM   #6
Xtreme_098
Xtreme_098's Avatar
Send a message via MSN to Xtreme_098
We'll, your going to have to rebuild your motor in order to do anything really. If you going all motor, well, yea you would rebuild the motor or it wouldn't really be all motor. You will blow your motor if you boost and don't rebuild it. Unless you boost at a low psi and thats not fun. I would recommend using Skunk2 for what you can. All their products are race proven and very reliable (www.skunk2.com). Use high compression pistons for a while. If you decide you want to boost, swap them for a lower compression piston. If you don't, you still have the high compression pistons. Save your money and do what you want to do.
Xtreme_098 is offline   Reply With Quote
Old 10-12-2004, 01:43 AM   #7
B18c_all_da_way
thanks a lot man much appreciated
Lex
