Old 10-08-2004, 10:42 PM   #1
thesixs
Question Turn signal issue
Our 94 Rodeo left turn signal is not functioning properly. Sometimes it flashes (too quickly) and sometimes you just get a high pitched electrical sound and no turn signal. The right functions properly. Also the headlight dimmer switch works perfectly fine. We have tried changing bulbs. Could this be the combination switch, or a short in a wire to left turn only??????
This is our second Rodeo. Our first is a 92 with 247K- still runs like a top
but the body is shot The 94 has 127K LOVE THEM RODEOS!!
thesixs is offline   Reply With Quote
Old 10-09-2004, 06:25 PM   #2
86TATpi
Where is the electical sound coming from?
86TATpi is offline   Reply With Quote
Old 10-10-2004, 05:57 AM   #3
rodeo02
I'd bet it's the combo switch. They take a beating over time. I don't think they are too difficult to r/r on these trucks.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
rodeo02 is offline   Reply With Quote
Old 10-10-2004, 12:22 PM   #4
thesixs
I am not sure where the sound is coming from. Possilbly the steering column. It is a buzzing instead of the normal turn signal clicking. Also, in case it makes any difference, the turn signal indicator light on the dash does not light on the left when the signal works or does not work. The right and four ways are fine. Thanks!
Old 10-10-2004, 03:45 PM   #5
86TATpi
Most likely the switch in the steering column.
Old 10-11-2004, 01:26 PM   #6
KAndrewL
Re: Turn signal issue
Mine buzzes too if I push it down slowly. A good sharp push and it happens less. I am pretty sure its the switch in the steering colum. When I got the car it did not work at all, but I found a wire in the steering column assembly that had broken away from its solder. When I replaced and "ohmed" out the switch at the connector as the Haynes manual suggests, I noticed that a left had turn was a lot more resistive than a right hand turn. left hand was in the 40 ohms region I think (its been a while) while a right hander was next to nothing (0). Probably a dirty switch or something.
Andrew
KAndrewL is offline   Reply With Quote
Old 10-11-2004, 10:29 PM   #7
2eyefishclaw
2eyefishclaw's Avatar
Send a message via AIM to 2eyefishclaw Send a message via Yahoo to 2eyefishclaw
you can take these apart and clean the contacts in them and they will work like new
2eyefishclaw is offline   Reply With Quote
