Old 09-29-2004, 09:42 PM
jackmalone2001 jackmalone2001 is offline
VATS problems
I am having problems with the PASS key II on my 1994 Chevy Camaro.
I pulled my car out of the Ohio River in Marietta last week and have to say I have made some huge strides toward getting my car back on the road.
I had it running two days ago for five minutes and turned it off because I need to change the oil a few times. But my point is that it runs on its own. So everything works, but I think my problem is with the key lock, and because I have no money, I cant replace it.
Now, two days later, I am having VATS problems and need some help to identify the wires that VATS uses to check the resistance of the key, coming from the steering colum. I have read in this forum that I can put a resistor to simulate the key in between these two wires to "fool" VATS.
I have taken a guage on the key and found it's resistance and want to put the right resistors in place so I can at least turn the engine over to change the oil and clean it out. Eventually I will install a new key lock.
Can someone please tell me which wires I need to place the resistor between and the easiest way to accomplish this?
Old 09-29-2004, 09:58 PM
twdz28 twdz28 is offline
Re: VATS problems
Took me a min to find it...
http://www.automotiveforums.com/vbul...highlight=vats
Do you want the security function to work? As a test, to see if it's the key switch, measure the resistance of the key pellet. Get a resistor close to the value of the pellet. Find the orange jacketed wires at the base of the steering column. Put the resistor across the contacts of the wires. If the light goes out and stays out, you have a problem with the key switch. If it still has the same problem, then the problem is with the wiring to the PCM or the PCM itself.
camaro's and corvettes are bad about the wires breaking at the key cylinder. since it works on and off thats probably whats happening...it's a pain to fix them, so what i would do is either A. take the pallet and measure the resistance go to radio shack and sauter the resistor in at the bottom under the dash... they are two white wires and have a connector at the base of the steering column. or B. you could just sauter the actual pallet in there....i don't recomend taking the column apart because its a tough job... there are circle clips on the steering shaft that are a pain. that will save you a lot of money, but your security system won't work... do you unlock your car with your key ? or with the keyless entry? next time get out and unlock the car with your key and see if that fixes it.. if so you'll need a new key fob!
You are dealing with the VATS. (vehicle anti theft system)
The VATS module verifies the value of the pellet on your key. If the value is not correct, the car will not crank.
If the key pellet is dirty, or the contacts inside the lock cylinder are worn it will fail and show the problem you saw.
Try to clean the key, then try a different key. If that does not work you may need to replace the lock cylinder.
95 Z28 Black on Black on Black. Mods: 355CI and lots more...
Originally Posted by Mordant
I'd say if they ask about material possessions then it's fair game to ask them what kind of underwear they wear, may as well get both sides expectations on the table as soon as possible.
Old 10-04-2004, 06:45 PM
will69camaro will69camaro is offline
Send a message via AIM to will69camaro
Re: VATS problems
I heard you weren't able to run a resistor to bypass the VATS...However they sell VATS bypass modules for fairly cheap and if (as in my case) your swapping the lt1 into an older car you can just have it wired out
William
