Go Back   Automotive Forums Car Chat > Ford > Sierra
Old 02-03-2004, 06:27 AM
sor777 sor777 is offline
Angry Help - Ford Sierra 2,0 DOCH Engine Problems !!
Hi Guys, I am a guy from Norway which have a seriouse problem with my Sierra 2,0 Doch 1991 modell. The engine is really hard to start and when you finaly get it started you need to work with it to the the rev up..! We tried to give it some "start gas" and then it rev up more easy, but there is no tourqe in the engine at all. And it runs like a "Lada" on low rev, so there is someting seriouse wrong. We have tried to change all of the sensors around, including the "brain box" and there is no change in anything what so ever.. So I thinke there is something we are missing out on here, the spark on the plugs are fine and fuel pressure are fine but its just like its not getting the right amount of fuel....!
Hope there is some out there which have had the same problem and are able to help out here - thanks in a million - to cold to walk around here in deep snow!!
Thanks
Arne
Old 02-12-2004, 12:57 AM
23turbo 23turbo is offline
Re: Help - Ford Sierra 2,0 DOCH Engine Problems !!
i dont know if u guys have catalytic converters, but my buddy, had a mr2, and same thing happend but his cat. exploded and clogged the exhaust. so maybe a possability?
Old 07-04-2004, 10:53 AM
Ford_Whore Ford_Whore is offline
Question
did you car make a rattling noise from the engine as it fires up? If so, it could be a worn gear on the distributor assembly. This causes the timing to go out when you start, until eventually it has worn away so much that the car cannot start (I think that the TDC sensor controls this function as well..) [i'm assuming you have an injection model, i don't know about the carb setup!]
or, it could be a badly blocked fuel filter..?
Old 04-21-2006, 06:53 AM
liquidlunch1812's Avatar
liquidlunch1812 liquidlunch1812 is offline
Send a message via Yahoo to liquidlunch1812
check your exhaust, could be a clog
2001 2.0 Jetta with 5 codes???? moemo '97 - '03 1 12-29-2009 06:22 PM
need vacuum diagram:'88 ram d-50,mitsu 2.0 liter cukoobajube Ram Pickup | Ram SRT10 0 05-31-2009 06:59 AM
Ford Sierra 2.0 L 1987 --> Won't start with warm engine alexpea Sierra 2 04-02-2007 01:29 AM
Help!! 96 jetta 2.0 no start problem dhavoc '91 - '96 3 02-14-2006 06:31 PM
1995 Ford Contour 2.0 auto tranny problem....ELECTRICAL? JUNKYARD? killer_cr80r Contour 7 07-21-2004 09:12 PM
